@hellm you got a bug on .17 release
Section 0x0742 , 0x0746 & 0x074a
A, B, C changes are applying but not visible read out in software
So far all is fine
There is a potential issue with:
0x0810 & 0x0812 not always applying, somewhy. But couple of attempts and a full reboot & it works
Keep up the hard work
EDIT:
Also lovely
EDIT2:
Let me know once that is fixed so i can redownload.
Alternatively, come over to PM~
@PJVol i'll answer later with correct tutorial
It's bit too early, else yes main ones
I suggest to zero out DcBTCmin/max both, at first. Redo curve on light 3D load , low amperage (heaven is one)
Watch FPS drops to stay always above 60 and work with VID.
Once that is done increase DcBtcMax in 6 steps, 100 is max. It's PSM. Is BtcMax does not adapt automatically, add BtcMin to force it run X "scalar"
Alternatively reverse idea, drop PSM Voltage slider and that cuts down Btc margin. Check how much voltage headroom you have. I got 150mV cut.
I would leave around 50mV delta, for DcBtc to do it's thing. Timespy is high amperage load and needs more voltage.
Btc does adapt that, but for clean curve generation, zero them out first
EDIT3:
Ahh i know what happens
@hellm
You reversed GFX & SOC field
Functionality is correct but both override fiels are "visually" swapped. Readout is swapped, functionality in corresponding field is correct
