So what 6800xt card you suppose to have per-part data set in a BIOS?
Can you rephrase please ?
I dont understand what was not understood
Or do you know for sure what settings need to be modified aside from VF points?
93% clear on DFLL & 78% on whole Navi
Guardband and PSM values i'm still learning ~ to fully understand AMDs tuning approach on factory level
FlopsPerByte i figured something out but its in testing phase
(i could use your analytic check if you find the time, need you in a group ~ if we share the same goal)
DFLL rebuild, yes mostly
// but i still have 2 weeks left
The most annoying part is, like you mentioned the start and ending points
// any change before or in post modifies the next one
Although i feel the ending points are artificial, as only drivers Limit back what it allows on automatic mode.
On OC mode (manual) things shift. The only lovely thing is, it holds to VID requests with up/down margins up to load indicators
// and those requests are not as dynamic as in Zen. They have fixed scaling and substrate appears very consistent between LkgID scores
The curve is neutral and can be isolated. That's great.
I am not confident on the sideeffects when relying on PLL offsets (correction) between cards
// i find non but there has to be something
So far it does not appear to bother FIT, but i see, bench and feel throttle limits in general. Especially on the FCLK side. Couple more days on that part.
We can track defaulting differences between bioses with UPP
We do know the driver Vmin/Vmax and Fmax limits (i requested extension on those)
We technically have everything that we need to redo curvature on all cards in the current state.
Crucial thing we lack are figuring out why DC extension limits are ignored, and still to cut away RSA check on EFI level (outside of card)
As for the curve itself. Up to perspective
If you see 5 chained curves as one and isolate each of them to be one thing.
Each have their margins. It's less guessing required because AMD did SKU binning for you
750,850,950,1050,1200
Anything between those points is an own Curve. Last is Vmax one, First pre-P0 is ULV & LowIdleVoltage (deep ULV)
Currently P0 is used, i dont get it sub 750 down to utilize ULV. It just utilizes BACO & GFX-OFF. I miss Access on PP-DFLL ULV_Offsets
Technically you don't "have to" take the extend on what you ask me.
You "don't have to" go that deep to make a 6900XTX have same substrate quality (curvature quality) settings as an 6950KXTX
^ but this is done too. I got it down to 1-2mV. KXTX utilizing XTXH curve with correction PLL offset == being the identical card.
Yuri's progress on 6700/6750XT is i hope going well. If not i'll take over. He is majorly unlucky by RL events, but time exists
I have to focus work on Navi 23 SKU a bit. This is paused as i wait for MPT. Many in the group are on ADL & can not use Hydra
Same time as FIT & UV Curve research is EVC research. Those two are on temporary halt. SOC has my main attention last days.
In generally yes,
Progress is made and i can work with PP-PW-Quadratic Curve.
I can not predict BTC stuff around it, only its effects.
I can not read out V to F points without by hand shuffling through it. (tracking when it switches P-States). A delay but bearable
^ this is main reason why Navi-Curve helper needs an update. But if you change approach and "predict/calculate" stuff, you can work with what you have.
I think this is fine as an answer on " are you very sure on what you do" ~ question
I don't have to understand everything to work with it, unless question was for a work offer.
You use current curve, with own tracked voltage & switching points. And adapt current curve (reshape). That's what navi curve helper does. You just need to change approach a bit , because it's usecase was initially different.
If anybody ever wants to bother for a Visual Plotter, all will be great. But we do with what we have.)
