I fully realise this is intended to work with some SKUs (probably 6x50, navi23), and not with the other (particulary those I mentioned),
Yes, 6800XT and 6900XTX are strange and left behind
6900XTXH & 6950 work (Navi 21)
6700, 6750 work (Navi 22)
6600 works (Navi 23)
Its more an AMD oopsy
~ all SKUs support it but it just misses sometimes
Some cards did not get newer vbios either, it takes time
Ones that dont work on stock , just can load an MPT from their same CU SKU and everything should be fine
Or check for bios updates.
EDIT: Or just fill it themselves sooner or later, hopefully sooner
We are in a state of powerplay custom modification and overclocking
A state where you can have multiple device entries & have to mess with registry.
One can expect (hopefully sooner when it's clearly visible) why it would or wouldn't work
A safety cap and auto toggle, would be more delay for a feature we need.
AMD is to blame, and less MPT Team
MorePowerTool is already an advanced book and not for people who don't know how to reinstall windows or boot to savemode to recover their card
Sure a warning wouldn't be bad, but the question resolves itself once all DFLL visibilities came.
The reason this toggle exists, is because the PW-Linear settings made no sense to exist "exactly because" cards were defaulting to DFFL #03 instead of 01
My time of silence expired and goal remains to get some progress done finally, after over a year or so.
I understand researcher's moodset that he was pissed about no progress on Navi since such a long time, and i can share the similar goal.
Soo i pushed hellm to logically add this DFLL selector (after September started), soo people can use PW-Linear in the meantime, till i can talk more about it
There is not one option i would take back, but rather even request for more work on
@hellm and remain team
Example:
FlopsPerByte sync values and remain PSM values to be editable.
We'll see what we really need. But removing stuff is the least we should focus on.
We "could" also request a cap on BTC to 100mV
But where do we go with that. Only more and more delays
Especially since options & functionality are open for change.
If it was for me, i would delay it further till the start of October. When all research between SKUs is done and ground set. To have my piece of credit
But its troublesome with a bigger group forcing everyone to buy Hydra + no support for Intel
And as it remains my part of work to decide what we do with curve and how far we push (no silentness anymore)
// i decided for public approach = let us use this, everyone of us and have a Programm that boots up fast , next to Hydra. Let's finally make some progress
Alternative option would be just to ask for a different UPP on windows , personal tool with Curve GUI approach
// which btw curve-helper dev is quiet, so i'll take that as an "i have no interest to continue this project"
If Hellm wouldn't be fit continuing his work.
I decided for MPT. So please let us keep what we have and expand further
Problem here and there, of course sometimes you'll hardlock drivers and have other side effects
it's fine
