@Veii and @everyone
(power/tdc uncapped, temps окay)
![1664450479438.png 1664450479438.png](https://www.igorslab.de/community/data/attachments/20/20689-03f330369cb022030726a8e87c567c1c.jpg)
Upd: nvm, it was power, but until a certain point, where clocks start stretching a lot (> 25mhz), seemingly due to lack of voltage.
Wanna see something funny:@Veii and @everyone
Ah... sorry, this was the specific way of talking with Veii since OCN ))
Would DC AVFS adapt itself by higher delta margins to AC
I think now I see what @hellm meant, lolThey are not really good in naming things, look at the Ac/Dc stuff.
No, should it?// do they say anything to you ?
Probably, as it's the odd 6800XT that uses themNo, should it?
This is not yet possible with RDNA2.Hi there,
I want to flash my RX 6600 from ASRock.
I saved the BIOS, loaded it into MorePowerTool and saved the MTP-file.
Then I openen Red BIOS Editor but could not load the MPT-file.
Do you have any idea what is causing the problem?
except? accept? expect?except
I wish you would supply a bit more positivity."Not yet" →also forget it for the future, I don't expect any flashing for rdna2.
