18:43:36:WU01:FS01
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
ownload complete
18:43:36:WU01:FS01:Received Unit: id:01 state
OWNLOAD error:NO_ERROR project:11744 run:0 clone:3650 gen:8 core:0x22 unit:0x000000118ca304f15e69ee0d50b56cf1
18:43:36:WU01:FS01:Starting
18:43:36:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\TimZopf\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 1820 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:43:36:WU01:FS01:Started FahCore on PID 10204
18:43:36:WU01:FS01:Core PID:10536
18:43:36:WU01:FS01:FahCore 0x22 started
18:43:37:WU01:FS01:0x22:*********************** Log Started 2020-03-18T18:43:36Z ***********************
18:43:37:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:43:37:WU01:FS01:0x22: Type: 0x22
18:43:37:WU01:FS01:0x22: Core: Core22
18:43:37:WU01:FS01:0x22: Website:
https://foldingathome.org/
18:43:37:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:43:37:WU01:FS01:0x22: Author: John Chodera <
[email protected]> and Rafal Wiewiora
18:43:37:WU01:FS01:0x22: <
[email protected]>
18:43:37:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 10204 -checkpoint 15
18:43:37:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:43:37:WU01:FS01:0x22: Config: <none>
18:43:37:WU01:FS01:0x22:************************************ Build *************************************
18:43:37:WU01:FS01:0x22: Version: 0.0.2
18:43:37:WU01:FS01:0x22: Date: Dec 6 2019
18:43:37:WU01:FS01:0x22: Time: 21:30:31
18:43:37:WU01:FS01:0x22: Repository: Git
18:43:37:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:43:37:WU01:FS01:0x22: Branch: HEAD
18:43:37:WU01:FS01:0x22: Compiler: Visual C++ 2008
18:43:37:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:43:37:WU01:FS01:0x22: Platform: win32 10
18:43:37:WU01:FS01:0x22: Bits: 64
18:43:37:WU01:FS01:0x22: Mode: Release
18:43:37:WU01:FS01:0x22:************************************ System ************************************
18:43:37:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
18:43:37:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
18:43:37:WU01:FS01:0x22: CPUs: 8
18:43:37:WU01:FS01:0x22: Memory: 15.96GiB
18:43:37:WU01:FS01:0x22:Free Memory: 11.36GiB
18:43:37:WU01:FS01:0x22: Threads: WINDOWS_THREADS
18:43:37:WU01:FS01:0x22: OS Version: 6.2
18:43:37:WU01:FS01:0x22:Has Battery: false
18:43:37:WU01:FS01:0x22: On Battery: false
18:43:37:WU01:FS01:0x22: UTC Offset: 1
18:43:37:WU01:FS01:0x22: PID: 10536
18:43:37:WU01:FS01:0x22: CWD: C:\Users\TimZopf\AppData\Roaming\FAHClient\work
18:43:37:WU01:FS01:0x22: OS: Windows 10 Pro
18:43:37:WU01:FS01:0x22: OS Arch: AMD64
18:43:37:WU01:FS01:0x22:********************************************************************************
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
roject: 11744 (Run 0, Clone 3650, Gen 8)
18:43:37:WU01:FS01:0x22:Unit: 0x000000118ca304f15e69ee0d50b56cf1
18:43:37:WU01:FS01:0x22:Reading tar file core.xml
18:43:37:WU01:FS01:0x22:Reading tar file integrator.xml
18:43:37:WU01:FS01:0x22:Reading tar file state.xml
18:43:37:WU01:FS01:0x22:Reading tar file system.xml
18:43:38:WU01:FS01:0x22
igital signatures verified
18:43:38:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:43:38:WU01:FS01:0x22:Version 0.0.2
18:43:57:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
18:43:57:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:44:25:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
18:44:25:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan
18:44:36:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
18:44:36:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan
18:44:48:WU01:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
18:44:48:WU01:FS01:0x22:Following exception occured: Particle coordinate is nan
18:44:48:WU01:FS01:0x22:ERROR:114: Max Retries Reached
18:44:48:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:44:48:WU01:FS01:0x22:Saving result file badstate-0.xml
18:44:50:WU01:FS01:0x22:Saving result file badstate-1.xml
18:44:52:WU01:FS01:0x22:Saving result file badstate-2.xml
18:44:55:WU01:FS01:0x22:Saving result file checkpt.crc
18:44:55:WU01:FS01:0x22:Saving result file science.log
18:44:55:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:44:55:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:44:55:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11744 run:0 clone:3650 gen:8 core:0x22 unit:0x000000118ca304f15e69ee0d50b56cf1
