Greetings and thank you all for your patience in advance. I have been playing with the WX cards (5100 and 7100) with good results as the user
@exhaustedbrit reports - some of the 5100's will only yield 19MH/s others 25 by reducing the Clock and boosting the VRAM clock. The 7100 with tweaking can get a stable 26 with decent temps. So with the crazy situation on cards I decided to try my luck with the W5500 and picked up two from ebay at a decent price. Stock I get 25Mh/s with decent temp. So I go to dump the BIOS and depending on what I use I either get a 512KB or I get 1,024KB file. Either one gives garbled info when I try to load them into Red BIOS Editor v1.07 and does not have most values like VRAM Timings. I have read carefully through this thread which is about the W5700 aside from a few mentions about the W5500. The learned member
@Mini_Me mentions in one post that it is "locked". I have learned much about the various settings of the WX series using PolarisBios Editor and was hoping to apply that knowledge to these cards but cannot figure out how to get at the BIOS settings to start modifying them. Has anyone had any luck with the W5500 and can point me in the right direction? Much gratitude for any tips.
