Tronado
Du mutiger Teufelskerl.Ich habe den PC mit 4090 und Cablemod 90° mittlerweile fast 24/7 an, Angst habe ich keine.
Ja, weil die Progger sind Kredit-HaieDenke mal nach dem Header Fail kommen noch Artikel über hohe Hotspots und eingetrocknete Wärmeleitpasten, die müssten sich demnächst auch häufen.
I'm sure you can pullup a new/used 4090 from the hat long time before you'll get back a repaired 4090/or refunded by Cablemod if the card go into HW heaven. I think the record wait time is 8 or 9 weeks for the worst screwed by their v1.0 angled adapters. This means over 2 months without gaming if you can't afford or have a spare GPU replacement. That's something to chew on, Igor Here home. My son forgot renew the Geforce Now sub. He has to pay 6 months sub if he wants to play again. But I had a spare card so he is now back into the game within hours. Of course... This won't help everyone if they are screwed by bad quality/bad QC for some so called high end products.It happens when it happens, but almost only with the 4090s and then mostly only with the inverse plugs and the PowerDraw over 500 watts. I know of a case with an MSI 4090 Suprim Then after a few days it went pffft. Your own fault. And it was a native Seasonic cable.
But the stuff doesn't burn, it just stews. And it smells like hell. I now have the PC with 4090 and Cablemod 90° on almost 24/7, I'm not afraid.
Hi. I'm not sure if you had me in mind or not. Anyway, I'm from Norway.May I ask where you live? Your English is quite interesting sometimes.
This is an advantage German customers have. I wouldn't even start arguing with the manufacturer, I would tell the vendor to solve the problem.
But Igor described a case where the product was altered and used beyond the specifications. In this case, you can say goodbye to warranty.
And start talking to KrisFix and pay 200€.
Thank you very much. It is an international audience here. So greetings to Norway. Nice to read you.Hi. I'm not sure if you had me in mind or not. Anyway, I'm from Norway.
What a suckerMit kleinen Spitzen gegen Steve/GN am Anfang
Vid von NorthridgeFix über geschmolzene Buchsen/Stecker bei 4090, die bekommen etwa 25 die Woche.
hast du absolute Zahlen zur 4090?Der Typ hat so recht... Die Teile stinken wie die Pest, ich habe die alle vakuumiert. meine Hände haben tagelang nach diesem Müll gestunken. Das geht nur mit offenem Fenster und Ventilator in Richtung offener Balkontür.
Das sind alles 4090er und ja, es sind weltweit schon richtige Stückzahlen. Weitaus mehr, als Cablemod jemals Adapter herstellen ließ
Im Übrigen hat NVIDIAs Adapter genau das gleiche Problem wie der Cablemod-Adapter, denn da stehen die Federn auch fix.
Und ganz ohne Grund habe ich den Aufwand nicht getrieben. Das hat auch nichts mit irgendwelchen YouTubern zu tun, sondern einem kapitalen Designfehler, der null Reserven inkludiert und schon ab Werk am Limit japst. Und Firmen, die es mal wissen wollten
Weil der reine Querschnitt das hergibt und man es schlicht und einfach zu wenig getestet hat. Solche Tests kann man vollautomatisiert durchführen. Die entscheidende Frage ist doch warum man das nicht gemacht hat?Warum die Manager geglaubt haben, das ein nur halb so großer Kontakt genauso gut funktioniert, bleibt deren Geheimnis.
