AMD RED BIOS EDITOR und MorePowerTool - BIOS-Einträge anpassen, optimieren und noch stabiler übertakten | Navi unlimited
@RedF
Man, what can you say about this result https://www.3dmark.com/spy/30707247 ?
I see it has the same specs and driver as yours, and roughly the same clocks for both, so I just wanna know your opinion.
Thanks.
Oh I didn't put much effort into TimeSpyExtreme.
My card will not have been very optimized for this.
But 1K ahead....
I just wanted you or anyone else to look closely at that score, particulary at the frequencies.
Eg CPU - the reported 5800x3d clocks 4712mhz ? Ok, this could be BCLK.
What about GPU, where the clocks to graphics score ratio is too far outside the statistical error?
Can anyone clarify if such inconsistencies could be indicative of possible cheating or is this a common thing with 3dmark telemetry?
What bothers me is the 77°C average temperature. The hotspot must have about 100°C.
Whether you get such a high score with such temperatures? I don't think so.
It's an air-cooled board, asrock PG, so the temps are typical for TSE @ ~ 400W )
May I know where I can find the BIOS for LC? I searched for many web pages and addresses but couldn't find them. I am a 6900XT graphics card from XTXH
may be as unverified@TPU database
Otherwise @ApolloX can help. He has the 6900LC.
It seems that there is no way to forcibly change the bios. Is there a good way? Masters QQ图片20230714165353.png
(paywall)
I have encountered a new issue. My VRAM was initially able to set to 2420MHZ and passed the test. The next day, it can only be set to 2412MHZ. Currently, only setting it to 2360MHZ will not cause the display to intermittently black out. Do I need to increase the voltage of DPM3 in MPT? Or, what did I set up incorrectly?
only@Benchmarking
you can try
@TDV-Section
SOC min1175mV max 1175mV
if the problem relies not to the Vram but SOC
just for fun
try less MVDD and later less VDDCI, may be with some 10MHz lower to find the Sweetspot
the cooler the vram stays the better it holds out without artefacts
(example is with good cooled vram by user holzmann)
Mal eine Frage : MPT und MCT erzeugen bei mir keine .Rom datei , woran kann das liegen? Ich möchte das Bios einer RX6500XT ändern , aber es funktioniert nicht.
Das geht auch nicht, nur noch über die SPPT. Also einge Registry einträge.
1. Bios der Karte extrahieren ( GPU-Z )
2. Bios ins MPT laden.
3. Werte anpassen.
4. Write SPPT und neustarten.
Bleibt bis zur nächten Treiberinstallation erhalten.
Ich habe auch ein Problem mit dem MPT:
Meine Graka ist eine Sapphire RX 6800 XT SE,sowie radeon 23.5.2.
Ich mache alles so, wie @RedF es im Thread über mir beschreibt. Aber wenn ich nach dem Neustart die neuen Werte im MPT noch mal ansehen will, werden mir nur die normalen Standardwerte angezeigt.
Woran kann es liegen?
Ich habe vor ein paar Wochen den RadeonSoftwareSlimmer 1.10.1 installiert, war das ein Fehler?
Ich hatte die MPT-Werte auf 180W, jetzt werden mir nur wieder die normalen 289W angezeigt.
Mehrere Neuinstallationen, auch mit DDU, brachten keine Änderung.
Hast du im MPT auch die Grafikkarte ausgewählt?
Was zeigt denn hwinfo64 beim GPU PPT an?
Graka ausgewählt hab ich, und das entsprechende .rom geladen.
PPT guck ich morgen mal.
So, noch eben schnell gemessen, PPT-Limit ist 289 W.
