Yeah, I worked with the basis on this article. But problem is that for vRAM hardset limits are too low (2248-2312), so i am bit confused because it is too easy to go over limit (if it works like that). And with voltages i have 0/0 in Temp. dependent Vmin from stock (i guess it is normal), not to say, as i already mentioned, i am especially careful with work on voltages, as i don't have much ways to ensure safety and actual voltages.You can use a translator and read through this tutorial, this link directs to the MPT part:
[Guide] - Navi 21 Max Overclocking Tutorial [6800 XT / 69X0 XT]
Wer wissen will, was die eigene Navi 21 Karte wirklich kann, aber nicht weiß, wie man das anstellt, der ist hier richtig. Ein Typischer Fall ist dieser: Karte gekauft und jetzt läuft die viel langsamer als bei den großen Jungs im Luxx Forum. Was tun? Inhaltsverzeichnis 1. Time Spy: das (fast)...www.hardwareluxx.de
Soc 1700 sounds too much, this does not improve your performance.
Safe part with Wattman tuning already had been done, so basically this is last step. And it may not be worth trying, it seems, tbh
