RedF
XTXH is an Extra binned 6900XT wit 1,2V on GPU.
You cant Flash your XTX ta a XTXH.
Only you can do is the Voltage Override. You just have to set the Vmin Low / High under Temperature Dependent Vmin to e.g. 1250mV and activate the Temp_Dependent_Vmin in the Feature Control.
Be carefull the voltage will be permanently high. Not good for daily use. Only good for benchmarks.
The Adrenalin Voltage Slider has no function anymore.
And you can Damage ur Card.
