- Mitglied seit
- Jun 1, 2018
- Beiträge
- 10.487
- Bewertungspunkte
- 19.654
- Punkte
- 114
- Alter
- 59
- Standort
- Labor
Das Lüfter-Zeuchs hab ich schonmal, und auch alle nötigen Infos um den Rest der Navi PowerPlay nun zu entschlüsseln. Dauert noch bisl..
Code :// SECTION: Fan Control 00 00 (°C) FanStopTemp; //Celcius 00 00 (°C) FanStartTemp; //Celcius . . 14 00 (0x14 = 20%) FanPwmMin; 34 08 (0x834 = 2100RPM) FanAcousticLimitRpm; 34 08 (0x834 = 2100RPM) FanThrottlingRpm; 56 13 (0x1356 = 4950RPM) FanMaximumRpm; 5A 00 (0x5A = 90°C) FanTargetTemperature; . .
Hello, I use Google Translate, Is the PowerPlay of 5700XT perfect? Can I edit it completely? For example, I want to modify the memory voltage, overclocking memory from 875mhz to 1000mhz, I think the default memory voltage is too low, which may cause the lack of memory overclocking.Thank you very muchOh, sorry, just forget about that one, doesn't work. The 50th Ed. is identified by the BIOS header, not over the PowerPlay table.
i am gonna delete it.
If you think you need more than 1,25V, for a benchmark run maybe (still not recommended), you have to figure it out like i said earlier here. Sorry, i will finish the whole table (very) soon, then you can read about every single byte. But i don't have much time for anything else right now, and we also working on an Update.. not telling anything yet.
german:
Ich hab bald die ganze Table fertig, und es wird wohl ein Update geben. Zeit ist wie immer der Faktor..![]()
