K
Greetings and welcome,Can anyone help me fix the 0FL01 error? I cannot flash my RX 5700 no matter what I try.
I'm using amdvbflash 3.04+ version from IgorsLab and the TechPowerUp. I tried flashing in Windows and in UEFI powershell from USB. I get the same error no matter what.
Plz help!
I believe everything you need are in the kindly attached link below,On another update. Afterflashing with V2.93+ , I tried CSM Enable in motherboard.
And i got into windows, though i have to disable and enable in device manager to remove the warning sign ! of the 5700xt .
Im not sure why it only works with CSM enable. But i am certain that i can flash VBIOS sucesfully now.
Mini_me, Do you know which VBIOS should i use for mining?
GYGABYTE OC GAMIN REV 2.0 Micron memory.
Thanks.
Why will it only post with CSM enable?
By the way, that is a relief as I do suggested before to other users to enable the CSM in the motherboard bios yet their problem which is the same as yours not worked, I believe they did not know how to properly enable the CSM,On another update. Afterflashing with V2.93+ , I tried CSM Enable in motherboard.
Thanks.
No, Thank you, for your time and support, It is MUCH APRECIATED.By the way, that is a relief as I do suggested before to other users to enable the CSM in the motherboard bios yet their problem which is the same as yours not worked, I believe they did not know how to properly enable the CSM,
My gratitude for your kind sharing this important information.
Thank you very much for your kind and informative feedback,No, Thank you, for your time and support, It is MUCH APRECIATED.
The important things to keep in mind are.
To use V2.93+ and
To use PCI 16x,
And CSM enable, if no post after restart from successful Vbios rom Flash.
A little note, when heatsink was remove, the 5700xt will remove almost instantly from Device manager (overheating).
So you need to the heatsink or other cooling solution, so the GPU wont shutdown.
sure, no problem.Thank you very much for your kind and informative feedback,
I would like to link your post to other threads if that is fine with you.
much appreciated.sure, no problem.
I posted it in the thread link kindly attached below,sure, no problem.
Were you able to fix this, I have same problem.I decided to remove the heatsink and give i try without the riser, and installing in the PCI 16x
Finally i could pass the rom test, and i coould flash the Vbios, With V2.93+ .
however after restarting windows, i will still not get post.
I tried using Gygabyte Tool with the Bios from Gygabyte OC gaming Rev 1.0 , even though my
Card i Rev 2.0. Use the tool restart after flash, and same thing.
I can only post shorting pins 1 and 8 of CMOS.
Should i RMA the Gpu at this point?
good morning!Hey and welcome,
Yes, please try shortening the 1 and 8 pins of the vbios chip.
try to use USB uefi flash tool , it work for me following the same @Mini_Me instructionsI decided to remove the heatsink and give i try without the riser, and installing in the PCI 16x
