K
Greetings and welcome,Can anyone help me fix the 0FL01 error? I cannot flash my RX 5700 no matter what I try.
I'm using amdvbflash 3.04+ version from IgorsLab and the TechPowerUp. I tried flashing in Windows and in UEFI powershell from USB. I get the same error no matter what.
Plz help!
Plz help!
Hello and welcome,Hello, sadly still showing the error 0FL01 and says SSID mismatched... there is something else that i can do?
Thank's its working now!!! you're the best!!Hello and welcome,
Please check the previous post as I updated it recently.
You are welcome.Thank's its working now!!! you're the best!!
Hey and welcome,Hey, i done the same.
Now when i am booting up (5700xt in 2. Slot) it would detect. No display driver notthing.
What i could flashed it back, i musted used 1+ 8 Option.
Thanks for your help.
~ I am German
You are welcome.Hey,
i did this and reflashed the Bios.
My Problem is fixed. I didnt plug a Cable from the cooler (not fans) in the GPU, so i had ~ 10 sec screen than black. Now it works. But thanks for your help
Hello and welcome,Thanks
Please use the command as below,Also i am using, PCI riser, and Mobo is set to PCI Gen2.
Tried on both, in v2.93+ and 3.04+ Ans till get Error.Please use the command as below,
amdvbflash -p -f 0 vbios.rom
and not
amdvbflash -fa -p 0 vbios.rom
Unfortunately from your gpu id which is 7310 that highly indicates your card have a hardware component fail that may need a replacement.Tried on both, in v2.93+ and 3.04+ Ans till get Error.
I am currently in safe mode. But it doesnt take effect.
Ok, thanks. for your help . I will RMA the card.Unfortunately from your gpu id which is 7310 that highly indicates your card have a hardware component fail that may need a replacement.
