AMD RTG Radeon Tweaker Group - AMD Radeon VII Mods, Tweaks, Untervolten und Übertakten leicht gemacht | igorsLAB
Labor
Die RTG (Radeon Tweaker Group) ist eine Gruppe derer, die es sich bereits seit AMDs Polaris und später auch Vega zur Aufgabe gemacht hat, so manche übervoltete und unnötig heiße Radeon zu dem zu machen, was man als Endkunde gern möchte: zu einer schnelleren und deutlich effizienteren Grafikkarte.
Hello
Does the driver version matter?
I simply exported the BIOS of the card from the LINUX.
On the Windows PC where I installed the TOOLS I wanted to read the ROM file.
I just wanted to know why I can not read the ROM file from a Radeon VII with the BIOS EDIT tool.
Look at the screenshot with the error message.
Thanks for your help
Regards Stone
Hello. I am having this problem on a 5700xt.
Changing any of these 2 voltages (VDDCI or MVDD), i write the SPPT successfully, then re-open morepowertool and it's still the same. I tried deleting and also used a random older version i had downloaded (1.3.7-final) and it's the same this.
Forcing to run as admin same thing (my account is already admin) still the same thing.
The program doesn't change these 2 values. Other values like power limit are saved. I can save the profile without saving sppt, with changes to mvdd and power limit and i see the power limit is there, but the mvdd change is default!
Definitely issue with the program.
(edit: i only tried undervolting)
Please help
edit: Driver: 22Q2
