***HYDRA 1.0F by 1usmus***
07/16/2023 21:24:48
Microsoft Windows NT 6.2.9200.0
AMD Ryzen 9 5950X 16-Core Processor
ASRock X570 Taichi
BIOS ver. P5.01 SMU ver. 56.74.00
TABLE ver. 3672069
DRAM speed 3200 MHz
Information about the last failure
Date: 07/16/2023 20:55:31
Unstable frequency, APIC ID: 9
If the failure occurred in a game:
Decrease by 25 the values for (GAME CO offset, SETTINGS tab).
If the failure occurred in a multi-threaded load (CPU usage > 75%):
In the CO table #2 reduce the CO for CORE#5 by 10.
Do not forget that too high a value of "AVX1 CO offset for MT" in "SETTINGS" tab
can also cause a system crash.
If the failure occurred in a low-threaded load (CPU usage < 75%):
In the CO table #1 reduce the CO for CORE#5 by 20.
Do not forget that too high a value of "AVX1 CO offset for LT" in "SETTINGS" tab
If the above information is difficult for you - press the "MINUS" button for both CO tables.
21:25:34: Boost testing started!
21:26:10: Boost testing finished!
HYDRA BOOST TESTER RESULTS
CORE / FREQUENCY / VID / POWER / TEMP
C01 F 4966 V 1.467 W 15.12 T 67.12
C02 F 4944 V 1.466 W 15.23 T 68.17
C03 F 4820 V 1.468 W 14.61 T 67.04
C04 F 4769 V 1.467 W 15.26 T 68.44
C05 F 4778 V 1.469 W 14.8 T 66.87
C06 F 4806 V 1.462 W 15.11 T 67.57
C07 F 4860 V 1.45 W 14.29 T 65.05
C08 F 98 V 1.464 W 1.14 T 41.9
C09 F 384 V 1.473 W 1.28 T 42.16
C10 F 4758 V 1.471 W 15.7 T 65.85
C11 F 4757 V 1.474 W 13.81 T 65.47
C12 F 4714 V 1.47 W 14.03 T 63.58
C13 F 4718 V 1.472 W 15.08 T 65.41
C14 F 4752 V 1.465 W 13.92 T 64.49
C15 F 4725 V 1.472 W 13.56 T 63.03
C16 F 4726 V 1.471 W 14.32 T 65.99
