AMD PROJECT HYDRA – OC-Sandbox für ZEN3 CPUs | Freeware-Download
Yuri Bubliy aka 1usmus geht nun nun dem Project Hydra einen komplett anderen Weg als noch mit dem am Ende etwas glücklosen CTR (Clock Tuner for Ryzen), obwohl die Ausrichtung und das Ziel bei beiden Programmen die gleichen sind: eine OC-Sandbox zur Optimierung aktueller Ryzen-Prozessoren von AMD, die auf Zen3 basieren. Beim Project Hydra hat (read full article...)
This might be of interest to others struggling with Hydra - I just installed a Seasonic Prime PSU which guarantees 0.5% voltage regulation. This has allowed me to run much lower values in curve optimizer (CO). It also completely changed the CO values that hydra came up with.
Before I was using a gold seasonic from 2012 that had ~3% voltage regulation. It seems that ryzen 5000 series is super sensitive to stable voltage, the poor quality VRM on my strix b450-F probably makes this even more evident.
So, nach ~8h ist mein 1. Durchlauf (nach 2 Reboots IIRC) durch.
Heraus gekommen ist:
Code :
Final ranking of cores:
       by AMD (CPPC)       | by real frequency
   C05   212   4900MHz   |   C06   4925MHz
   C03   212   4875MHz   |   C01   4925MHz
   C04   208   4900MHz   |   C05   4900MHz
   C08   203   4850MHz   |   C04   4900MHz
   C02   199   4850MHz   |   C07   4875MHz
   C06   194   4925MHz   |   C03   4875MHz
   C07   190   4875MHz   |   C08   4850MHz
   C01   185   4925MHz   |   C02   4850MHz
   C09   181   4800MHz   |   C14   4825MHz
   C15   176   4725MHz   |   C12   4825MHz
   C12   172   4825MHz   |   C10   4825MHz
   C11   167   4800MHz   |   C16   4800MHz
   C14   163   4825MHz   |   C11   4800MHz
   C16   158   4800MHz   |   C09   4800MHz
   C10   154   4825MHz   |   C13   4775MHz
   C13   149   4775MHz   |   C15   4725MHz
Unreceived frequency due to incorrect CPPC tags
   1T   50MHz
   2T   50MHz
   3T   25MHz
   4T   50MHz
   5T   25MHz
   6T   25MHz
   7T   0MHz
   8T   0MHz
   9T   25MHz
   10T   100MHz
   11T   100MHz
   12T   75MHz
   13T   75MHz
   14T   75MHz
   15T   50MHz
   16T   0MHz
CURVE OPTIMIZER values for BIOS
(If you do not plan to use HYDRA)
C01    SAFE CO: -30    MID CO: -30    FAST CO: -30
C02    SAFE CO: -27    MID CO: -30    FAST CO: -30
C03    SAFE CO: -1    MID CO: -1    FAST CO: -1
C04    SAFE CO: -25    MID CO: -30    FAST CO: -30
C05    SAFE CO: -10    MID CO: -12    FAST CO: -15
C06    SAFE CO: -30    MID CO: -30    FAST CO: -30
C07    SAFE CO: -30    MID CO: -30    FAST CO: -30
C08    SAFE CO: -28    MID CO: -30    FAST CO: -30
C09    SAFE CO: -30    MID CO: -30    FAST CO: -30
C10    SAFE CO: -30    MID CO: -30    FAST CO: -30
C11    SAFE CO: -30    MID CO: -30    FAST CO: -30
C12    SAFE CO: -30    MID CO: -30    FAST CO: -30
C13    SAFE CO: -30    MID CO: -30    FAST CO: -30
C14    SAFE CO: -30    MID CO: -30    FAST CO: -30
C15    SAFE CO: -26    MID CO: -30    FAST CO: -30
C16    SAFE CO: -30    MID CO: -30    FAST CO: -30
Min CPU Boost Clock Override: 0MHz
und sie safe Werte flux in's BIOS eingetragen. Bis auf C03 (und C05) scheint es für mich (entgegen erster Erwartungen) zumindest ein Energieeffizientes Exemplar zu sein. Bei meinem ASUS B550-itx musste ich etwas suchen um die PBO2 Settings zu finden - es ist nicht unter dem Ai Tweaker zu finden, sondern unter AMD Overclocking (man muss runter scrollen).
Bevor ich die Settings im UEFI eingetragen habe, habe ich wohl (irgendwie ungewollt, weil ich dachte das war's schon bei der Free Version) den Multi-Threaded Cinebench angestoßen. Dieser ist aber gleich kommentarlos abgestürzt. Nach etwas experimentieren in den CB23 Einstellungen zeigte sich dann, dass ich nur ~24 Threads max. verwenden durfte. Irgendwie kam auch eine Meldung im Hydra, dass 220W überschritten wurden.
Nach dem Eintragen der CO Values im BIOS kann ich nun auch 32 Threads laufen lassen (für 5 min. bisher nur). Allerdings limitiert mein NCase M1 Noctua C14 hier, die CPU throttelt ständig bei den 90°C (lt. CoreTemp und Task-Mgr). Lt. CoreTemp liegt nun der Verbrauch der CPU bei < 210W.
An sich wollte ich nun mit PPT/TDC/EDC limits spielen (d.h. senken) um die Kiste kühler und damit leiser zu bekommen, aber der Cinebench Crash macht mich da nachdenklich? Oder verwechsle ich da etwas?
PS: Die Exemplar Angabe Platin/Gold/Silber/Bronze ..., gibt's nur in der PRO Version?
PPS: Cinebench ist durch mit 27751 Punkten mit Hydras CO Werten im BIOS
Code :
   1T   50MHz
   2T   50MHz
   3T   25MHz
   4T   50MHz
   5T   25MHz
   6T   25MHz
   7T   0MHz
   8T   0MHz
   9T   25MHz
   10T   100MHz
   11T   100MHz
   12T   75MHz
   13T   75MHz
   14T   75MHz
   15T   50MHz
   16T   0MHz
die gold silber platin usw angabe ist in jeder Version (kannst mir ja das Log schicken, müsste recht weit unten sein die Angabe)
Das mit den 220W, da musst du mal in den Hydra einstellungen suchen, nicht das du da zu niedrige limits hast
Wenn du die BIOS curve optimizer werte nutzt, dann Hydra auf jeden die Profile Deaktivieren, oder halt erst gar nicht mehr Starten
[...]Das mit den 220W, da musst du mal in den Hydra einstellungen suchen, nicht das du da zu niedrige limits hast[...]
220W ist die Voreinstellung von Hydra. Er meint aber vermutlich eine Fehlermeldung von Hydra am Ende der Analyse. Da wird CB23 nicht ausgeführt bzw. es crasht weil das Powerlimit gerissen wird. Fehlermeldung kommt auch wenn man vergleichen möchte. Das Problem besteht auch wenn man in Hydra die Limits erhöht. Ich konnte einen Lauf ohne diese Fehlermeldung bisher nur mit im Bios manuel eingetragenen, signifikant höheren Limits beseitigen.
Ja, du hast ja 2x PBO im bios, wenn da in dem auf der Hauptseite niedrigere Limits drinnen sind, dann hängt das wohl da dann
Der quasi Vorführeffekt. Ich habe es eben noch einmal mit in Hydra angepassten Limits ausprobiert (260W, 260A und 220A) und schon läuft der Vergleich wieder. Also hast Du anscheinend doch recht. Ich lasse gleich noch einmal einen Analyselauf starten. Mal sehen ob der jetzt durchläuft mit angepassten Werten.
Ja, genau:
Das sind die Einstellungen (default):
d.h. ich sollte obiges einstellen und CineBench probieren - und nichts raucht ab? Ausser dass die Temps ~90° werden und die CPU dann drosselt?
Sehe ich das richtig, das Hydra die Settings zur Laufzeit checked? Wenn es aus ist, klappt CB, mit Hydra eben nicht.
Zudem, 1641669257698.png bedeutet wohl dass diese aus sind, yep?
  • 2022_01_08__12_27_38 PM.txt
Ja, genau:
Zudem, Anhang anzeigen 16938 bedeutet wohl dass diese aus sind, yep?
Im Log fehlt noch was, im nächsten sollten die Bewertung stehen ^^
Sobald das PPT limit erreicht wurde, geht Hydra aus, ja
Das mit der Laufzeit kapier ich grad nicht ganz?
Und ja, wenn da "Activate Profiles" steht, dann sind sie aus
Wenn du nur die Bios Werte nutzen willst, brauchst du Hydra auch nicht mehr laufen lassen
bzw. ich würde jetzt mal schauen, ab welchem TDC Wert (entweder in Hydra oder hwinfo64 beobachten) deine Temps ausser Kontrolle geraten, und dann im Bios halt bei PBO diesen Wert etwas niedriger reinschhreibst
Nein, sollte eigentlich immer drin sein. Scheint aber hier und da unterzugehen oder nicht komplett bis zum Ende durchzulaufen, in meinen letzten beiden Durchläufen nach neuer CPU steht auch nichts drin. Einfach die Logs nach "sample" durchsuchen, so findet man das recht zügig, wenn vorhanden.
Da raucht nichts ab, nein. Wenn Hydra als Software nicht drosselt, tuts die Hardware. Solang Hydra läuft, werden PPT, EDC und TDC überwacht und bei Überschreitung der Werte wird dann der Anker geworfen, richtig.
Mit Laufzeit meinte ich lediglich, dass Hydra läuft.
Ansonsten Danke für die Hilfe, morgen geht es weiter.
So, ich habe nun die Defaults für PPT, TDC und EDC (142W, 95A, 140A) eingestellt im Ryzen Master (BIOS kommt später), damit habe mit ~80° CPU noch etwas Luft im Hochsommer. Dabei lief CineBench und auch der Furmark für Gfx und die kleine Kiste wurde nur erträglich laut. Ohne diese Einträge war's schon echt laut. Im CB takten die Cores auf ~3.8MHz - aber ich render die wenigeste Zeit und auch ein kompletter Virusscan (läuft auch voll paralllel) zwingt mich nicht zu Ohrenstöpsel :) Beim CoreCyler mit Prime bin ich bei ~4.7GHz - je nach Core natürlich.
Wenn der Rechner mal wieder Luft hat, lasse ich Hydra mit den BIOS CO Einstellungen nochmals laufen - ohne Profile. Mal sehen, was rauskommt, denn Gold, Silber, Bronze - das interessiert mich nun doch etwas.
Vermutlich ist noch etwas Luft nach oben, aber ich bin soweit zufrieden; aber so ein kleiner ITX Gehäuse ist halt kühlungstechnisch limitiert.
Die Bewertung der CPU ist in irgendeinem Log, musst das nicht noch einmal laufen lassen
Ich kann nur Gutes berichten. Ich habe mich an Leiv's Kurz-Tutorial gehalten und mein 5800X läuft jetzt erheblich kühler mit geringerem Verbrauch (Watt) und bei höchstens 1% Verlust bei Cinebench R20. Ich hab absolut nichts zu meckern!
Vielen Dank an Juri und an Leiv!
Die 1.1A Pro Version ja, bei der 1.0F weiß ich es gar nicht
  • Like
Bewertungen: tcd
  • Like
Bewertungen: tcd
