- Mitglied seit
- Jun 1, 2018
- Beiträge
- 10.485
- Bewertungspunkte
- 19.652
- Punkte
- 114
- Alter
- 59
- Standort
- Labor
Die habe ich selbst ![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Aber Danke, denn es spart mir einmal ein- und ausbauen.![Thumbs up (y) (y)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
==============NVSMI LOG==============
Timestamp : Sat Dec 08 20:50:52 2018
Driver Version : 417.22
CUDA Version : 10.0
Attached GPUs : 1
GPU 00000000:01:00.0
Power Readings
Power Management : Supported
Power Draw : 40.02 W
Power Limit : 300.00 W
Default Power Limit : 300.00 W
Enforced Power Limit : 300.00 W
Min Power Limit : 150.00 W
Max Power Limit : 345.00 W
Power Samples
Duration : 111.96 sec
Number of Samples : 119
Max : 83.98 W
Min : 39.55 W
Avg : 43.96 W
Timestamp : Sat Dec 08 23:26:49 2018
Driver Version : 411.95
CUDA Version : 10.0
Attached GPUs : 1
GPU 00000000:1B:00.0
Power Readings
Power Management : N/A
Power Draw : N/A
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Power Samples
Duration : Not Found
Number of Samples : Not Found
Max : Not Found
Min : Not Found
Avg : Not Found
Timestamp : Sat Dec 08 23:14:09 2018
CUDA Version : 10.0
Attached GPUs : 1
Power Readings
Power Draw : 6.63 W
Power Limit : 120.00 W
Default Power Limit : 120.00 W
Enforced Power Limit : 120.00 W
Min Power Limit : 60.00 W
Max Power Limit : 140.00 W
Power Samples
Duration : 13.94 sec
Max : 9.81 W
Min : 5.96 W
Avg : 6.49 W
Timestamp : Sat Dec 08 21:12:22 2018
Driver Version : 416.34
CUDA Version : 10.0
Attached GPUs : 1
Power Readings
Power Draw : 24.56 W
Power Limit : 250.00 W
Default Power Limit : 250.00 W
Enforced Power Limit : 250.00 W
Min Power Limit : 125.00 W
Max Power Limit : 300.00 W
Power Samples
Duration : 5.42 sec
Max : 68.41 W
Min : 20.79 W
Avg : 32.59 W
Timestamp : Sat Dec 08 23:05:38 2018
CUDA Version : 10.0
Attached GPUs : 1
Power Readings
Power Draw : 11.62 W
Power Samples
Duration : 9.06 sec
Max : 14.23 W
Min : 10.85 W
Avg : 11.39 W
Timestamp : Sat Dec 08 21:38:15 2018
CUDA Version : 10.0
Attached GPUs : 1
Power Readings
Power Draw : 3.64 W
Power Limit : 260.00 W
Default Power Limit : 260.00 W
Enforced Power Limit : 260.00 W
Min Power Limit : 100.00 W
Max Power Limit : 320.00 W
Power Samples
Duration : 13.55 sec
Max : 12.43 W
Min : 3.22 W
Avg : 3.97 W
Never change a running system.Interessant ist auch die Varianz, der Treiberversionen. Bisher gesehen 391 bis 417. Und das alles bei Techis.
Timestamp : Sun Dec 09 18:10:37 2018
Driver Version : 399.24
Attached GPUs : 1
Power Readings
Power Draw : 17.25 W
Power Samples
Duration : 4.32 sec
Max : 17.65 W
Min : 14.20 W
Avg : 15.62 W
Timestamp : Fri Dec 21 20:07:49 2018
Driver Version : 417.35
CUDA Version : 10.0
Attached GPUs : 1
Power Readings
Power Draw : 63.70 W
Max Power Limit : 375.00 W
Power Samples
Duration : 7.48 sec
Max : 63.97 W
Min : 12.98 W
Avg : 26.19 W
Timestamp : Sun Jan 27 22:07:26 2019
Driver Version : 411.70
Attached GPUs : 1
Power Readings
Power Draw : 21.50 W
Power Limit : 160.00 W
Default Power Limit : 160.00 W
Enforced Power Limit : 160.00 W
Max Power Limit : 216.00 W
Power Samples
Duration : 120.18 sec
Max : 21.77 W
Min : 21.25 W
Avg : 21.45 W
Timestamp : Sun Jan 27 22:13:36 2019
Driver Version : 391.01
Attached GPUs : 1
Power Readings
Power Draw : N/A
Power Limit : 75.00 W
Default Power Limit : 75.00 W
Enforced Power Limit : 75.00 W
Min Power Limit : 52.50 W
Max Power Limit : 75.00 W
Power Samples
Duration : 4.67 sec
Max : 35.48 W
Min : 35.46 W
Avg : 35.46 W
Timestamp : Sat Dec 05 02:33:01 2020
Driver Version : 457.30
CUDA Version : 11.1
Attached GPUs : 1
Power Readings
Power Draw : 325.36 W
Power Limit : 350.00 W
Default Power Limit : 350.00 W
Enforced Power Limit : 350.00 W
Max Power Limit : 400.00 W
Power Samples
Duration : 18446744073709.51 sec
Max : 359.97 W
Min : 268.94 W
Avg : 0.00 W
