[Updated]
Please, use the official Gigabyte bios with its own flashtool in the kindly attached link below to reflash and fix any bricked Gigabyte RX 5700/5700 XT GAMING card:
One can download other vbios for other Gigabyte cards from official Gigabyte site however only the UK, Russian and Taiwan ones, below for Gigabyte UK official site,
Discover AORUS premium graphics cards, ft. WINDFORCE cooling, RGB lighting, PCB protection, and VR friendly features for the best gaming and VR experience!
www.gigabyte.com
This bios is modifiable as well by changing the R57XTGAMING-OC-8GD.BIN in the BIOS folder after extraction to R57XTGAMING-OC-8GD.ROM,
Please note:
You can only update the VBIOS of the same series. This BIOS flashing requires Visual C++2008.
How to update the BIOS of your graphics card ?
- By Windows (only for Gigabyte RX 5700 XT GAMING OC):
1. Extract the downloaded GV-R57XTGAMING-OC-8GD-FA0.zip below.
2. Boot to Windows Safe Mode and execute GV-R57XTGAMING-OC-8GD.exe as an Administrative.
3. Click StratFlash.
4. Wait for the update to complete and reboot.
- By FreeDOS (for all Gigabyte RX 5700/5700 XT GAMING):
1. First disable secure boot in bios settings,
2. Download Rufus program from the official link below, and make a FreeDOS bootable USB flash drive,
Rufus is a small application that creates bootable USB drives, which can then be used to install or run Microsoft Windows, Linux or DOS. In just a few minutes, and with very few clicks, Rufus can help you run a new Operating System on your computer...
rufus.ie
3. Download the Amdvbflash_DOS v4.68 from the link below, and extract the amdvbflash.exe and put it with the official Gigabyte bios R57XTGAMING-OC-8GD.BIN or the backup bios file in the FreeDOS bootable USB flash drive, the USB flash drive must be connected to a USB 2.0 port,
4. Reboot and press f12 until a boot list appear and choose the bootable usb flash drive,
5. Now enter these commands:
amdvbflash.exe -i
Press Enter
It will show you the gpu adapters list occupying the pcie slots for an example if there is only one gpu then its adapter number will be 0.
amdvbflash.exe -unlockrom 0
Press Enter
It will unlock the gpu chip for flashing if it is locked.
amdvbflash.exe -s 0 chooseAname.rom
Press Enter
To make a backup of the gpu bios if needed.
amdvbflash.exe -p 0 vBios.rom
Press Enter
To flash the bios, here -f or -fa to force the flash in case of error.
Why can't the BIOS of my graphics card be updated to the latest version on the website ?
GIGABYTE graphics cards have different BIOS series under the same model name. Generally speaking, the BIOS versions of Gigabyte graphics cards belong to the same series from F1 to F9, and from F11 to F19 are also belong to the same series, and so on. Therefore, if the BIOS version of your graphics card is F3 and F4/F10 is available on the website, the BIOS of your graphics card will be updated to F4 instead of F10. |
