Meine GTX 1070 hat gerade ein Paket bekommen, wofür sie 24h benötigen wird![]()
Meist geht die Dauer runter, wenn ein paar Prozent gerechnet sind. Am Anfang hat er da scheinbar nen Standardwert, der dann auf die reale Performance wechselt.
Passiert, wird aber mit jedem Tag besser. Manchmal hilft es den Client neu zu starten.
Was macht deine Vega so pro WU an Punkten?
15:06:23:WU02:FS00ownload 13.59%
15:06:29:WU02:FS00ownload 19.99%
15:06:35:WU02:FS00ownload 27.02%
15:06:41:WU02:FS00ownload 43.21%
15:06:47:WU02:FS00ownload 52.77%
15:06:53:WU02:FS00ownload 66.20%
15:06:59:WU02:FS00ownload 79.39%
15:07:05:WU02:FS00ownload 92.50%
15:07:07:WU02:FS00ownload complete
15:07:07:WU02:FS00:Received Unit: id:02 stateOWNLOAD error:NO_ERROR project:14533 run:0 clone:1797 gen:8 core:0x22 unit:0x0000001180fccb025e72f1fbffcb2d36
15:07:07:WU02:FS00:Starting
15:07:07:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Pascal\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 2352 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:07:07:WU02:FS00:Started FahCore on PID 660
15:07:07:WU02:FS00:Core PID:10064
15:07:07:WU02:FS00:FahCore 0x22 started
15:07:08:WU02:FS00:0x22roject: 14533 (Run 0, Clone 1797, Gen 8)
15:07:08:WU02:FS00:0x22:Unit: 0x0000001180fccb025e72f1fbffcb2d36
15:07:08:WU02:FS00:0x22:Reading tar file core.xml
15:07:08:WU02:FS00:0x22:Reading tar file integrator.xml
15:07:08:WU02:FS00:0x22:Reading tar file state.xml
15:07:08:WU02:FS00:0x22:Reading tar file system.xml
15:07:09:WU02:FS00:0x22igital signatures verified
15:07:09:WU02:FS00:0x22:Folding@home GPU Core22 Folding@home Core
15:07:09:WU02:FS00:0x22:Version 0.0.2
15:07:23:WU02:FS00:0x22:ERROR:exception: Error invoking kernel sortShortList: clEnqueueNDRangeKernel (-5)
15:07:23:WU02:FS00:0x22:Saving result file ..\logfile_01.txt
15:07:23:WU02:FS00:0x22:Saving result file science.log
15:07:23:WU02:FS00:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:07:23:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:07:23:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:14533 run:0 clone:1797 gen:8 core:0x22 unit:0x0000001180fccb025e72f1fbffcb2d36
15:07:23:WU02:FS00:Uploading 8.00KiB to 128.252.203.2
15:07:23:WU02:FS00:Connecting to 128.252.203.2:8080
15:07:24:WU01:FS00:Connecting to 65.254.110.245:8080
15:07:24:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:07:24:WU01:FS00:Connecting to 18.218.241.186:80
15:07:24:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:07:24:ERROR:WU01:FS00:Exception: Could not get an assignment
15:07:25:WU01:FS00:Connecting to 65.254.110.245:8080
15:07:25:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:07:25:WU01:FS00:Connecting to 18.218.241.186:80
15:07:25:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:07:25:ERROR:WU01:FS00:Exception: Could not get an assignment
11:55:42:WU02:FS01:Server responded WORK_ACK (400)
11:55:42:WU02:FS01:Final credit estimate, 80599.00 points
11:55:42:WU02:FS01:Cleaning up
