- Mitglied seit
- Jun 1, 2018
- Beiträge
- 10.843
- Bewertungspunkte
- 20.544
- Punkte
- 114
- Alter
- 60
- Standort
- Labor
Spitzenperformance
Spitzenperformance
Yes! The irony is that I fixed this exact problem just yesterday, so please try it with my patched version of the tool Igor. The version that DedSec linked didn't allow overwriting of the Device ID, so here is a version that also allows that:Die FEs sind nunmehr flashbar.
Yes, but TPU doesn't contain your BIOS file yet in their collection. Perhaps Igor is willing to share the BIOS file with you.Heißt das jetzt das ich die RTX 2070 ARMOR flashen kann? Wenn ja mit welchem Bios? Jemand ne Anleitung ?GreeTz
And wait for Igor to try this out first. I know that people have been able to flash their FE card with BIOS files from other cards, but in that scenario it was "only" reporting a Board ID mismatch. Now that in this example we're also seeing a Device ID mismatch so wait for Igor to test this out and see if the card is still functional after performing the flash.@Tow,
just go ahead and ask Igor. I suppose he will do it.
The 2070 Armor to gaming Z flash won't work (deinstalled driver or DOS mode and the both patched nvflash versions)
C:\Results>nvflash64_patched.exe MSI2070Gaming.rom --overridesub
NVIDIA Firmware Update Utility patched by Vipeax
Copyright (C) 1993-2018, NVIDIA Corporation. All rights reserved.
Checking for matches between display adapter(s) and image(s)...
Adapter: Graphics Device (10DE,1F02,1462,3734) H:--:NRM S:00,B:01,D:00,F:00
EEPROM ID (9D,7014) : ISSI IS25WP080 1.65-1.95V 8192Kx1S, page
WARNING: None of the firmware image compatible PCI Device ID's
match the PCI Device ID of the adapter.
Adapter PCI Device ID: 1F02
Firmware image PCI Device ID: 1F07
Alternate: 1F2E
WARNING: Firmware image PCI Subsystem ID (1462.3732x
does not match adapter PCI Subsystem ID (1462.3734).
WARNING: None of the firmware image compatible Board ID's
match the Board ID of the adapter.
Adapter Board ID: 00D8
Firmware image Board ID: 00D9
PCI Device ID override detected.
(This is usually only needed for very special circumstances.)
Are you sure you want to continue?
Type "YES" to confirm (all caps):
YES
Overriding GPU PCI Device ID mismatch
Please press 'y' to confirm override of PCI Subsystem ID's:
Overriding PCI subsystem ID mismatch
*** WARNING: Overriding the Board ID can be very dangerous. ***
Upgrading to an image with the wrong Board ID can render the video card
unusable.
Overriding the Board ID is only needed for extreme circumstances.
A mismatched Board ID almost always means the wrong firmware image is being
used for the specific video card.
YES
Overrding Board ID mismatch
Current - Version:90.06.0B.40.38 ID:10DE:1F02:1462:3734
GPU Board (Normal Boardx
Replace with - Version:90.06.0B.40.12 ID:10DE:1F07:1462:3732
Update display adapter firmware?
Press 'y' to confirm (any other key to abort):
Storing updated firmware image
Command complete with error, Error code = 0x005A
EEPROM programming failed.
NOTE: Exception caught.
Nothing changed!
PROGRAMMING ERROR: EEPROM Program failed
