Anhang anzeigen 26921 Anhang anzeigen 26923 Anhang anzeigen 26924 Anhang anzeigen 26922
I tried "ausgeflackert v6.0.mpt" still causes flicker, and my flicker is like this , Minimize the program again to restore it.
up to now , 240Hz has been changed to 280Hz OR disable ds+gfx_ off can solved.
flickering may have multiple causes it is depending from hardware, software and configurations and fixes are individual for different cases.Hi, i have the same issue on my XFX 6750XT.
The GPU some times when I start the pc starts to flicker or while I'm on the desktop after reactivating the pc screen. Is there any way to solve this problem ?
I solved the problem by setting the freesync range to 40 - 144hz on the CRU.flickering may have multiple causes it is depending from hardware, software and configurations and fixes are individual for different cases.
The tutorial is specific for the TUF-RX6700XT-O12G, cause there are hundreds of unlucky owners in many forums, who have the exactly same issue.
So troubleshooting in your case could be different
for the flickering at your PCs boot procedure in your case, is this independent of the OS you are booting?
Have you tried to boot in Windows and Linux?
What are the things you have already tried out to fix the flickering?
For now after setting the freesync range the problem hasn't reappeared. This problem only occurred with Freesync turned on
Hi I have a question, I have just tried these settings, only feature control for now, if it works I won't change the other settings. But I am not sure I fully understand how this works. So correct me if I am wrong. I save my bios, make a backup, than I load my bios in MPT. After that I change the settings which you have shown here (again I only changed feature control ones) and click write SPPT. Reboot. And that is it? Can these settings be reverted, do they go back after a driver install?Here are the settings to ensure flacer and artifact free operation when using the global standard settings.
Left ≙ Original Bios TUF-RX6700XT-O12G-GAMING.
Right ≙ Adjustments to the SPPT for flicker and artifact free operation.
What do we want to drink for 7 days, what do we want to drink... and we don't fall asleep, we don't drink alone together
Maintain the minimum power limit reduced to 6
This is a balance act because the GPU memory seems to be more thirsty than the memory.
For this I increased the RAM voltage from the mainboard from 1350 to 1360 mv and with the MVDD there are about 1,370 mv according to hardware info sensors. I also wanted to synchronize the Soc voltage with the mainboard, but here too less leads to crashes and more to a flicker.
So I've been running free of flicker and artifact for over a week...
And in the idle the card pulls 10 watts which is ok for me.
You can read here the MPT-Tutorial in English:Hi I have a question, I have just tried these settings, only feature control for now, if it works I won't change the other settings. But I am not sure I fully understand how this works. So correct me if I am wrong. I save my bios, make a backup, than I load my bios in MPT. After that I change the settings which you have shown here (again I only changed feature control ones) and click write SPPT. Reboot. And that is it? Can these settings be reverted, do they go back after a driver install?
I don't understand why RAM voltage matters here, I have my VDIMM at 1,39V because my RAM is OCed.You can read here the MPT-Tutorial in English:
RED BIOS EDITOR and MorePowerTool for Polaris, Navi and Big Navi | Page 3 | igor´sLAB
New curve options have been added. Of course we would be very happy about a feedback in the forum about the use of this new function! The More PowerTool (MPT) has been also revised once again for the…www.igorslab.de
After you changed settings, you can save the MPT config file in a folder of your trust. If you update the gpu driver, you have to rewrite the MPT config Settings to the SPPT.
You can check if the Method from @Hu0ke work for you, by simply disable gfxoff in feature control. If it works, fine, if it crash or flicker again, than you can try the settings I explained in german, or just load my config file in MPT from here:
AMD - Edit: "Solved" @ 04.08.2023! Entflackerungs- und Entartefaktions-Tutorial der TUF-RX6700XT-O12G-GAMING unter Windows 11 und MPT Stand 04.08.2023
Bei diesem GPU Modell gibt es viele User, welchen das Geflackere der Karte bislang trotz AGESA GPU und Chipsatztreiber Updates unter Windows 11 erhalten bleibt. Und ist dieses durch Deinstallation von Windows Updates, Chipsatz- und GPU-Treibern sowie der Mainboard Hersteller-Software und...www.igorslab.de
And wirite it into the SPPT. But last thing of course only, if you have the Same GPU: TUF-RX6700XT-O12G-GAMING
If your system RAM works well on 1,36 voltage you can also try to change this in your Bios config. Or try to manually syncronise your RAM and V-RAM voltage and look at HWinfo f.e. if it matches.
"This is a balance act, cause the GPU memory seems to be thirstyer than the RAM. (so in my case)Dies ist ein Balance Akt da der GPU Speicher einen größeren Durst zu haben scheint, als der Arbeitsspeicher.
Dazu habe ich die RAM- Spannung vom Mainboard von 1350 auf 1360 mv erhöht und bei den MVDD liegen bei diesen Einstellungen etwa 1.370 mv laut Hardwareinfo Sensoren an. auch die Soc Spannung wollte ich mit dem Mainboard synchronisieren, aber auch hier führt weniger zu Abstürzen und mehr zu einem Geflacker.
Seems your settings don't work for me, I tried changing everything. Though I must admit it seems to be less frequent, like a lot less. So maybe I am on the right track? I'd like to know your opinion on what I should change, my VSOC is 1.125V here and in BIOS, I used your 1.356V DPM 3 value but my VDIMM is at 1.39V, is it safe to push DPM3 to 1.39V? Also I have a question that is unrelated to this. I always felt that I could push this card further with an OC, but even in heaviest games at 4K the power draw caps at around ~190W, where as it's limit is at 233W. Do you think that increasing TDC limits gfx and soc, would make the card pull more power, and achieve higher clocks? If so what is the furthest I could go without causing damage?"This is a balance act, cause the GPU memory seems to be thirstyer than the RAM. (so in my case)
To do this, I increased the RAM voltage from the motherboard from 1350 to 1360 mv and the MVDD at these settings are about 1,370 mv according to HWinfo sensors. I also wanted to synchronize the Soc voltage with the motherboard, but again, less leads to crashes and more causes flickering."
You can try to syncronise your RAM and VRAM Voltage (@DPM 3 in MPT Picture above) in my case it runs more stable.
I have seen you mentioning that newer drivers increase flickering frequency. I wonder have you tried amernime drivers? If this issue is connected to gpu drivers, maybe these ones work better.My intention was, to find Settings that are able to fix flickering issues, not to gain Pervormance.
If you find Settings who work for you, maybe the method of Hu0ke by only disable gfxoff will work in your case,
than you can look within this Settings for possibilitys to gain Performance. Otherwise you will recieve Performance improfments but this also may improve the Flickering intensity. Wich has allready increased by the last 2 AMD Drivers, at least in my case. So if i look what is happening without SPPT modifikations.
So in your case i wolud first try gfxoff, if it wors fine, if not, than find a Way by slowly increase the memory voltage to 1362 and if flickering still happen lower the gfx and Soc voltage to 1190 gfx and 1122 Soc if it crashes after that it was maybe to much, if it still flickering work in the same slowly stepps until you find your sweet spot without crashes or flickering.
And to your question about Power Limit i have decrease it to 193 to recieve a non Flickering enviroment for radeon stock settings, and also in customized graphic Profiles, wich you can see here: https://www.igorslab.de/community/t...-11-und-mpt-stand-04-08-2023.8176/post-219952
It shows results @ a Score over 14000, to 14260 in Time Spy, so it's enough for me. but shure if i want, i could reach more, but i don't think this is necessary.
