Beim CTR 2.1 habe ich ca einmal die Woche beim Windows Hochfahren einen CTR Fehler.
Kann man was dagegen machen?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at A.c7ef8ec682dd21d60b7ea8e49e2ff83f2.c3fc703dfbda1b86430b15596c6c05928(Object c277b280cb8fe3785a6c267498280c752, EventArgs c8da54f451ad34b6795b09c79d576523f)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Nemesis UIv2
Assembly Version: 2.1.5.23
Win32 Version: 2.1.5.23
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/CTR%202.1.exe
System
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Nemesis UIv2&&
Assembly Version: 1.0.0.0
Win32 Version: 4.8.4341.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Bunifu_UI_v1.5.3
Assembly Version: 1.5.3.0
Win32 Version: 1.5.3.0
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu_UI_v1.5.3.DLL
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Management
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Windows.Forms.DataVisualization
Win32 Version: 4.8.4200.0
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
Bunifu.UI.WinForms.ToggleSwitch
Assembly Version: 1.11.5.2
Win32 Version: 1.5.5.2
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu.UI.WinForms.ToggleSwitch.DLL
Bunifu.UI.WinForms.BunifuTextbox
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu.UI.WinForms.BunifuTextbox.DLL
Bunifu.UI.WinForms.BunifuPages
Win32 Version: 1.11.5.2
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu.UI.WinForms.BunifuPages.DLL
Bunifu.UI.WinForms.BunifuFormDock
Win32 Version: 1.6.0.0
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu.UI.WinForms.BunifuFormDock.DLL
Bunifu.UI.WinForms.BunifuDropdown
Win32 Version: 1.5.7.1
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu.UI.WinForms.BunifuDropdown.DLL
Bunifu.UI.WinForms.BunifuToolTip
Win32 Version: 1.9.0.0
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu.UI.WinForms.BunifuToolTip.DLL
Embeded
Assembly Version: 0.0.0.0
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu.UI.WinForms.BunifuFormDock.dll
Bunifu.Core
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu.Core.DLL
System.Runtime.Serialization
Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
System.Data
Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml.Linq
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Embeded
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu_UI_v1.5.3.dll
Embeded
CodeBase: file:///D:/eigene%20dateien/Downloads/CTR%202.1%20RC5%20CB20/Bunifu.UI.WinForms.BunifuToolTip.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
