Question 5600XT BIOS flashed with mod from Red BIOS Editor, there is an issue
ricardo
Hello and thank you for everything. Currently, I have a 5600XT in which I have flashed the modified bios by Red BIOS Editor. However, the BIOS did not work, the system hangs during POST. This is no problem, I am used to flashing BIOS with SPI Programmer CH341a, I am free to test anything.
I think maybe this did not work due to the fact that my card is dual BIOS, and when I read the BIOS from the memory chip, it comes out with 1024kb, rather than the 512kb saved from GPU-Z. When I try to open this extracted BIOS with RBE, it modifies fine, but does not save by stating "An unknown error occurred when accessing (filename path). This is not a permission issue, I am running admin. It works fine to save the file when I use the GPUz extracted rom. However, even with the 512KB file, it does not work to post the card.
I have tried several things, the last one was to make only a very small change on the GFX Maximum Clock to 1900MHz. It still does not work. I originally made a BIOS with a lot more changes and limits, such as 2100, 1000 memory, more power, voltage, etc, etc. but decided to make a small alteration to see if it would work-- unfortunately it doesn't.
I have also tried to open in HxD the original long file 1024kb and noticed it makes no difference, because after 000FFFF0 it is only 0's anyway. Also, in HxD, I have tried to open the original stock BIOS and overwrite the part, leaving the correct file size, but this also did not work to POST. Stock BIOS still works fine when re-flashed, card is perfect.
So, I am leaving a link to my files, to see if we can figure out why the modified BIOS is not working on my 5600XT.
Here is the URL: http://xonedigital.com/BIOS_etc.zip
on this ZIP file, there are the following:
1 - 5600xt1_gpuz.rom (Original BIOS from the card extracted with GPU-Z)
2 - 5600xt-stock_extract.rom (This is the BIOS file extracted from the Chip with SPI Programmer, it loads on RBE, but fails to save)
3 - mpt-1900_only.mpt (This is an example of a small change I tried to see if it would work, only changing maximum clock to 1900mhz)
4 - 1900-ONLY-BIOS1.rom (This is the final outcome of RED BIOS EDITOR using the GPU-Z BIOS with the MorePowerTool settings of 1900mhz)
I hope this helps, thank you so much for all your work again and let me know if anything else is needed. I am really looking forward to free up the power of this 5600XT :)
Thanks again!
A BIG thanks to Mini_Me for providing a perfectly flashable BIOS !
I've been able to lower GPU voltage to 700 mV and apply 1550 MHz timings to 1750 and 1800 MHz steps.
Now the card delivers 42,02 Mh/s at 83 W, 117 W on wall !
GPU is now at 1150 MHz, don't seem to gain any performances at 1300 MHz
VRAM make all perf actually : upped from 1840 to 1846 MHz to go from 41,89 to 42,02 Mh/s
Seems stable so far, still waiting for invalid shares
Still have to apply -40% Power Target to lower GPU SoC Voltage at 806 mV (can't hard modify it).
Memory voltage stays at 850 mV (can't modify it)
Hi could you share the bios? I have the same card and flashed the msi redpanda mining bios. I get more MHS with the redpanda bios but the temp of the mem is to high and the power consumption are also higher.
This is the org bios from the Powercolor Card.
regards chris
  • RadeonRX5600XT-6G-Micron_GDDR6-113-D199XLE.rom
@Mini_Me hey I was wondering if you could unlock the bios for the TUF 3-RX5600XT-O6G-EVO-GAMING for gaming rather than mining? P/N: 90YV0EA0-M0AA00
  • Asus.RX5600XT.6144.200313 (1).rom
Hi all,
I'm new here. I'm looking for a bios mod for my ASUS TUF Gaming RX 5600 XT's. On the stock BIOS they're able to produce about 38.9mh/s using HiveOS with a Core Clock of 1250, Core Voltage (VDD) of 775 and a Memory Clock (MEM) of 910. I've tried pushing the memory but it always becomes unstable. Is there a repository of BIOS's that have been previously modified or is each one individually created?
Anyway, to this end, I have attached the stock BIOS (extracted via HiveOS) in the hope that someone here maybe able to help, The particulars of the cards I have are as follows:
TUF 3-RX5600XT-T6G-EVO-GAMING
Part No: 90YV0EA1-M0NA00
Warm regards
Matt
  • RadeonRX5600XT-6G-Samsung_GDDR6-115-D199PI0-101.rom
Greetings everyone,
My apologies for the delay and the inconvenience,
I know I mentioned before that I am going to post all the unlocked vbios files on a new thread however I find there are many versions out there therefore a better solution is founded that is implementing the unlocking method in RedBiosEditor after Mr. Igor permission and Mr. Hellm agreement as a possible solution, this will make anyone able to unlock any Navi 10 731F vbios they want without any delay anymore and I believe this will make everyone happy,
Thus your further patience is needed and highly appreciated as currently working on this is already started despite our current circumstances and limited time however anyone and everyone of you are not forgotten at all,
My gratitude for your kind understanding,
Please stay safe and healthy,
Regards.
Greetings everyone,
Regards.
Please tell me how can I unlock, because I tried many times but the result always was a brick card :D
This is how I tried:
1. Save rom with cpu-z.
2. Load saved rom in mpt (1.3.4)
3. Change only one thing (example: Fan speed, or min voltage from 800 to 750, whatever.)
4. Save changes to mpt file.
5. Load rom in rbe latest version (1.0.7)
6. Open saved mpt file with rbe.
7 Save rom.
8. open cmd (with admin) and run these command with amdvbflash 3.0.4+ version:
amdvbflash.exe -unlockrom 0
(rom unlocked succesfully)
andvbflash.exe -f -p 0 saved.rom
(cmd says the f parameter isn't available, then flashes the rom successfully)
9. I restart the pc and it's cant start anymore. The bios's checking routine stop on the flashed card. The screen is black and noting happens.
Only one way to solve this problem (and it's very dangerous): I start the pc with another card, and after the checking routine but before windows start I switch the riser's adatpter to the flashed card. When the widows started I can restore the original rom with the 8th step.
If I change anything in the rom, after the flash the card dead. Only the original rom can be flash.
What am I spoiling?
What am I missing?
I flashed dozens of rx4xx and 5xx series cards, I know the cards and the parameters what I want to set, but the flashing process fo the 5600 series won't work for me :(
Thank you!
7 Save rom.
What am I spoiling?
What am I missing?
Thank you!
Hey just saying, if you do brick the card, if you have the extra pcie slot, put the working card in that and boot up using that but with the 5600 still in the system (has to have the power cable in as well) and just run amdvbflash -i to make sure ur 5600 is still recognized on 0 and u can just reflash from there.
Greetings,
I believe until now all requests had already been fulfilled,
For those who their vbios is not listed on bitby.ru, please feel free to message me whenever you like.
hi
can you help me please
There is no BIOS for my gpu card in bitby.ru
Asus RX 5600 XT 6 GB ROG STRIX MEM Micron
P\N 115-D182PI0-100
  • stock5600xtbios.rom
Dear @Mini_Me,
could you do me a favour and unlock my Asus RX 5600 XT?
Thank you very much.
Original rom attached.
  • rx5600.rom
Dear @Mini_Me,
Love the great work you are doing. I cannot OC ASUS RX 5600 xt above 38 mhs. I don't know if this has something to do whether locking of the BIOS. Could you take a look?
ASUS TUF 3-RX5600 XT T6G EVO gaming TOP
P/N: 90YV0EA1-M0NA00
  • Asus.RX5600XT.6144.200313.rom
Dear @Mini_Me,
Thank you so much for your work!
Would you be so kind and take a look at the BIOS of my ASUS Radeon RX 5600 XT 6GB DUAL EVO TOP?
P/N: 90YV0EJ1-M0NA00
I would love the get also the last percentages out of it.
Stock Bios is attached.
Much appreciated & Thank you again for your effort,
Best Regards
  • ASUS_RadeonRX5600XT-6G-Micron_GDDR6-115-D189P00-100.rom
Hei @Mini_Me
I have uploaded wrong bios to my Sapphire Pulse rx5600xt BE. PN S88-4E416-002SA.Is it possible to help me with reversing to old bios. When trying to flash it subsystemids mismatch pops up. I would like to unlock it as well please.
Hi @Mini_Me
I'm trying to modify the RX5600XT Thicc II Pro 150W for mining and, well, I'm struggling at the same problem the other users.
Could you unlock the BIOS?
Part number: 113-150WCNAVIXLE6GB
I really appreciate your help
Hi @Mini_Me
Hi @Mini_Me
I also need a modified version of the bios on this subject. can you help me please.
Hi Mini_me!
I wonder if you could help me unlock my ASUS Strix 5600 XT TOP id 1043 4EC and bios p/n is 115-D182PI0-100
I think it has both Micron and Samsung memory but i am unsure. It will be used for mining.
Thanks very much for your help!
Best Regards,
Nick
  • Asus5600XT_TOP.rom
Hello Mini_me! Salutes from Canada!
First thank you so much for your amazing help in bios modding/unlocking.
Can you please unlock my ASUS ROG Strix 5600 XT
SSID: 04EC
Product name: 731FHB.17.1.0.49.AS51P
Really appreciate you!
With kind regards,
rollyrose
  • asus-rog-strix-5600xt-original-bios.rom
Looking for an unlocked / modded eth bios for my Gigabyte 5600XT 6GD / F60 / 09F9 Rev 1.0 Card
GV-R56XTGAMING OC-6GD
attached is my original!
  • GIGABYTE GV-R56XTGAMING OC-6GD-F60-09F9.rom
Hello can anyone please help me.
I have 1 5600xt card.
Its an Asus Tuf 5600xt top t6g evo gaming.
If i try to mod the stock bios myself, it bricks the card.
I have also tried numerous bios found on the web including redpandamining's and nothing worked.
I always have to flash the stock bios on hiveos to get it to work.
This card has been driving me crazy. Stuck @ 39mhs and always dead and reboots after a few hours.
Thank you so much in advance for the help.
  • JonaTin-1-RadeonRX5600XT-6G-Micron_GDDR6-115-D199PI0-101.rom
Bonjour @Mini_Me ,
Comme beaucoup de gens ici, j'ai un problème avec mon 5600 xt (Sapphire Pulse rx5600xt BE. PN S88-4E416-002SA).
Je pense que je l'ai cassé avec un mauvais bios.
Dès le premier démarrage, j'ai obtenu :
- impossible de démarrer mon rodi ce qui m'a donné un écran noir (je ne pouvais même pas voir le bios de mon ordinateur..)
-> J'ai réussi à passer cette étape avec l'astuce du trombone (connecter deux pattes du microprocesseur ensemble).
- Je ne sais pas si je vais pouvoir démarrer mon ordinateur, mais je suis sûr que je pourrai voir ma carte 5600 dans amdvbflash_win.
Le problème que j'ai est que je ne peux pas obtenir un nouveau BIOS stable pour fonctionner avec.
Les problèmes que j'ai :
-- "error in Vbios image" : j'ai pourtant essayé plusieurs BIOS ou erreur 0FL01.
J'ai essayé plusieurs BIOS, mais même quand j'essaye d'appliquer celui que j'ai sauvegardé, ça ne marche pas (c'est celui joint à ce mail)
- J'ai essayé tous les amdvbflash : 3.04, 3.04+, UEIF, windows.
- Les commandes de retour que j'utilise sont :
CMD dans l'administration
amdvbflash -i (parfois je ne peux même pas voir ma carte donc je dois redémarrer) ;
amdvbflash -unlockrom 0 (0 est l'emplacement de ma carte)
amdvbflash -f -p 0 nombios.rom
- sous les fenêtres :
amdvbflash
J'essaie de sélectionner un bios mais à chaque fois j'obtiens: "erreur dans l'image Vbios".
Dans le cadre de l'IUEF :
J'ai "impossible de lire la ROM".
Est-ce que "Insttool64.exe" est obligatoire avec la version windows et la version DOS ?
Le bios que je dois injecter est-il de 512 ou 1 Mo ?
est le bon bios que j'ai ??
J'ai essayé tous les amdvbflash : 3.04, 3.04+, UEIF, windows... Quelqu'un peut-il me dire ce que je dois faire car j'ai peur d'avoir cassé ma carte...
Merci beaucoup à vous tous !
Traduit avec www.DeepL.com/Translator (version gratuite)
  • Navi_10_bios_original.rom
  • original.rom
Hi @Mini_Me,
Could you please help me to unlock and optimize Asus ROG-STRIX-RX5600XT-O6G-GAMING (Micron) bios rom for mining ?
Attached is original bios.
Thanks in advance!
  • ASUS-RadeonRX5600XT-6G-Micron_GDDR6-115-D182PI0-100.rom
