Question 5600XT BIOS flashed with mod from Red BIOS Editor, there is an issue
ricardo
Hello and thank you for everything. Currently, I have a 5600XT in which I have flashed the modified bios by Red BIOS Editor. However, the BIOS did not work, the system hangs during POST. This is no problem, I am used to flashing BIOS with SPI Programmer CH341a, I am free to test anything.
I think maybe this did not work due to the fact that my card is dual BIOS, and when I read the BIOS from the memory chip, it comes out with 1024kb, rather than the 512kb saved from GPU-Z. When I try to open this extracted BIOS with RBE, it modifies fine, but does not save by stating "An unknown error occurred when accessing (filename path). This is not a permission issue, I am running admin. It works fine to save the file when I use the GPUz extracted rom. However, even with the 512KB file, it does not work to post the card.
I have tried several things, the last one was to make only a very small change on the GFX Maximum Clock to 1900MHz. It still does not work. I originally made a BIOS with a lot more changes and limits, such as 2100, 1000 memory, more power, voltage, etc, etc. but decided to make a small alteration to see if it would work-- unfortunately it doesn't.
I have also tried to open in HxD the original long file 1024kb and noticed it makes no difference, because after 000FFFF0 it is only 0's anyway. Also, in HxD, I have tried to open the original stock BIOS and overwrite the part, leaving the correct file size, but this also did not work to POST. Stock BIOS still works fine when re-flashed, card is perfect.
So, I am leaving a link to my files, to see if we can figure out why the modified BIOS is not working on my 5600XT.
Here is the URL: http://xonedigital.com/BIOS_etc.zip
on this ZIP file, there are the following:
1 - 5600xt1_gpuz.rom (Original BIOS from the card extracted with GPU-Z)
2 - 5600xt-stock_extract.rom (This is the BIOS file extracted from the Chip with SPI Programmer, it loads on RBE, but fails to save)
3 - mpt-1900_only.mpt (This is an example of a small change I tried to see if it would work, only changing maximum clock to 1900mhz)
4 - 1900-ONLY-BIOS1.rom (This is the final outcome of RED BIOS EDITOR using the GPU-Z BIOS with the MorePowerTool settings of 1900mhz)
I hope this helps, thank you so much for all your work again and let me know if anything else is needed. I am really looking forward to free up the power of this 5600XT :)
Thanks again!
Hello @Mini_Me
I have an Asrock RX 5600XT Challenger PRO (Samsung GDDR6 113-EXT800128-L02) and couldnt find an unlocked rom.
İ think you helped some people on top of the topic but i cant find bios link :) Can you please help me for unlocked rom.
Thanks for your effort. Have a nice day.
  • Asrock_Rx5600xt_Samsung_original.rom
Greetings everyone,
For those who want unlocked 5600 XT vbios, there is a great guy who do great job at doing that even perhaps better than my work in the kindly attached link below, you can support him if you like,
You may have a good day,
Regards.
Greetings everyone,
Regards.
Great!
Thanks!
Are memory timings set here for gaming or mining?
Greetings everyone,
Regards.
@Mini_Me "Boa noite"
I gave it a try but their unlocked bios are tested only on linux and mining OSes.
I even talked with "bitby" by telegram.
His bios unlock doesnt work for windows like yours does.
PS: My black screens was been caused by my ryzen OC, your bios is perfect for the Asrock Challenger, thanks and congrats for your unsurpassed work.
Radeon software got buggy with their BIOS:
I also had the locked at 800 issue on Windows, you need to modify the bios from 5600 XT to 5700 on MPT, after that the clocks are no longer locked. I don't know if it has the stock timings or modded.
I tried the one for my sapphire and the ram seems to be more stable
Greetings everyone,
Anyone who have Sapphire 5600 XT card that after unlocking the card and when changing the memory timings the card is not working properly in mining then message me as I might have found a way to bypass this problem safely.
@Mini_Me Did you find a fix for the timing issues on Sapphire cards for mining?
@oscarp
So you loaded a 5700 mpt on the 5600XT unlocked bios?
I just edited the 5600XT mpt and loaded on the unlocked BIOS.
Wich 5700 mpt did you loaded?
Dear @Mini_Me. I have a sapphire 5600 xt black edition. Would you kindly unlock the bios for me? I wish to game better with it. I am very much indebted to your help.
The SKU number is 11296-05-20G
The product number is S88-4E416-002SA
Here is the original BIOS
Gonna try it tonight.
I wanna help other to unlock their BIOS too.
If changing the device Id works i gonna make a tutorial and publish
I believe the tutorial is unneeded as I am going to post all unlocked vbios for all models of all brands for both gaming and mining, this way the risk is eliminated and the only things remain are to apply Apple Inc. optimized memory timings straps and the optimized power table.
Mini_Me
I have a 5700XT that will not run after I flash the BIOS, can you tell if it is locked for me please?
Kind Regards
Matthew
  • Matthews_PC-1-RadeonRX5700XT-8G-Micron_GDDR6-xxx-xxx-xxx.rom
Utiliza a bios disponível no RedPandaMining youtube channel.
Gigabyte Gaming OC 8GB
Please choose the appropriate vbios in the kindly attached link below,
Hi everyone, new modder here! I am stuck with my situation. I have PowerColor Red Devil RX 5600XT OC. I just can't get my head around this, why I don't get it to work. If some one please can check my situation out. I've included explanation, photos and files in this .zip https://www.file-upload.net/en/download-14483503/apu.zip.html . Please and thank you!
Power Colour Red Devil RX 5600 XT NAVI10 DV L0120JAF.ROM 140W 15418 G25 875 XLE1 6GB
BIOS: 017.001.000.049.000000
Micron memory
Use case is for gaming, so I want to max out my card as much as possible, power draw can be high as well as temps.
