Question 5600XT BIOS flashed with mod from Red BIOS Editor, there is an issue
ricardo
Hello and thank you for everything. Currently, I have a 5600XT in which I have flashed the modified bios by Red BIOS Editor. However, the BIOS did not work, the system hangs during POST. This is no problem, I am used to flashing BIOS with SPI Programmer CH341a, I am free to test anything.
I think maybe this did not work due to the fact that my card is dual BIOS, and when I read the BIOS from the memory chip, it comes out with 1024kb, rather than the 512kb saved from GPU-Z. When I try to open this extracted BIOS with RBE, it modifies fine, but does not save by stating "An unknown error occurred when accessing (filename path). This is not a permission issue, I am running admin. It works fine to save the file when I use the GPUz extracted rom. However, even with the 512KB file, it does not work to post the card.
I have tried several things, the last one was to make only a very small change on the GFX Maximum Clock to 1900MHz. It still does not work. I originally made a BIOS with a lot more changes and limits, such as 2100, 1000 memory, more power, voltage, etc, etc. but decided to make a small alteration to see if it would work-- unfortunately it doesn't.
I have also tried to open in HxD the original long file 1024kb and noticed it makes no difference, because after 000FFFF0 it is only 0's anyway. Also, in HxD, I have tried to open the original stock BIOS and overwrite the part, leaving the correct file size, but this also did not work to POST. Stock BIOS still works fine when re-flashed, card is perfect.
So, I am leaving a link to my files, to see if we can figure out why the modified BIOS is not working on my 5600XT.
Here is the URL: http://xonedigital.com/BIOS_etc.zip
on this ZIP file, there are the following:
1 - 5600xt1_gpuz.rom (Original BIOS from the card extracted with GPU-Z)
2 - 5600xt-stock_extract.rom (This is the BIOS file extracted from the Chip with SPI Programmer, it loads on RBE, but fails to save)
3 - mpt-1900_only.mpt (This is an example of a small change I tried to see if it would work, only changing maximum clock to 1900mhz)
4 - 1900-ONLY-BIOS1.rom (This is the final outcome of RED BIOS EDITOR using the GPU-Z BIOS with the MorePowerTool settings of 1900mhz)
I hope this helps, thank you so much for all your work again and let me know if anything else is needed. I am really looking forward to free up the power of this 5600XT :)
Thanks again!
Thank you @Mini_Me for your help.
after flashing unlocked bios i get stable 41.5 mh/s
if someone can help me to get more hash or less watt
thank you
Hello Mini_Me,
Please, can you unlock my bios, card XFX 5600XT Thicc II Pro.
Thanks
  • Navi 10 TII x177 Performance.rom
Hello Mini_Me,
I have a XFX RAW II 5600xt. If you could unlock my bios please.
Thanks in advance
  • XFX_original.rom
hey @Mini_Me
I have a ASROCK challenger pro RX5700xt PN: 90-GA24ZZ-00UAN
I'm using for mining, I tried to flash bios with out much success, I noticed it has micron and Samsung memory and cant seem to find any good working bios that will work with this card. i was wondering if you could help?
Thanks in advanced!
  • AP_5600xt_stock.rom
hi and thanks for the excellence post but i have the same problem as everyone that has locked bios from asrock as u mentioned @Mini_Me this companies locks theirs graphics cards for business purpose, i have been following all your post and i have followed all the process since the gigabyte bios that u posted until this one with the Radeon RX 5600 XT Challenger Pro 6G OC got problems too, i modified with no success could u please help me i got the original rom, i am new but this process its so exiting thanks in advice, bro, i set all config vram in apple numbers but as u know the card failed to work same issue with the gigabyte that i could mod thanks to your unlocked bios, please send me some king of id or btc addres for a tip pal, what else u need beside the stock rom ?
  • stockbiosasrock.rom
Hi @@Mini_Me
I have a MSI Radeon 5600 XT Gaming MX and I was having the same problem many people had. Looks like my regular bios modding didn't work and would get the black screen. Hopefully you can help me out!
Thank you!
  • AMD-01-0-RadeonRX5600XT-6G-Samsung_GDDR6-113-MSITV381MH.3HO.rom
Hello everyone,
i also need help with my 5600 xt
i have the SAPPHIRE PULSE 5600 XT BE with samsung memory, for minning
@Mini_Me can you please unlock the bios for me?
thank you
  • rx5600xt.rom
@Mini_Me Can you unlock this bios for me ? It's from a 5700 non-XT. I Will use to upgrade my friend's gpu to a 5700xt, thanks!
  • Asus.RX5700.8192.200116.rom
merhaba @Mini_Me ..
safir nabzım 5600xt var ..
bios rom programının kilidini açmam gerekiyor.
orjinal rom'um orada..pls bana yardım et ..
  • hiveosorginal.rom
Hi!
I come here with the same problem as most. I have a XFX 5600 XT Pro Thicc II card with dual bios and i bricked both of them. I don't have an integrated mobo to flash them back to the original, but that is something that I can sort out, I think.
I've been using the regular adrenalin tweak capabilities with the official bios from XFX. It looks like the memory clock cannot be set to higher than 1630 MHz, possibly because it is the 12Gb version FML. Beyond that, I get failures in shards and driver crashes. Is that a hardware limit or by unlocking I could get the desirable 1850+?
The idea was getting more hash power, but I also game with that card. Would it be feasible to get the two and switch the bios bank as needed?
Because I cannot boot, I cannot get the onboard default bios. The part number is RX-56XT6DFD6 and the bios at the homepage are:
Performance bank: http://xfxstorage.com/Support/BIOS/Video/AMD/5600XT/56XT6150.zip
Quiet bank: http://xfxstorage.com/Support/BIOS/Video/AMD/5600XT/56XT6125T2.zip
Thanks in advance, @Mini_Me, you're tha man!
@Mini_Me is an unlocker GOD guys!!! Thank you so much. Asrock challenger pro with Samsung memory unlocked and modded successfully. I'm at 43.370 MH/s. It's crazy!
