Arctic
NZXT
P12 PWM PST RGB 0dB
F120 RGB
26 mm
159 g
205 g
500 U/min
1800 U/min
0.4 W
1.8 W
48.8 CFM
50.2 CFM
82.9 m³/h
85.2 m³/h
1.85 mmH2O
2.70 mmH2O
27.5 dBA
Grau
Halbtransparent
4.0 V
4.7 V
2.9 V
4.4 V
380 U/min
827 U/min
532 U/min
703 U/min
1985 U/min
1924 U/min
447 U/min
32.1 CFM
+32.8 %
24.2 CFM
23.9 CFM
+26.4 %
18.9 CFM
23.0 CFM
+77.0 %
13.0 CFM
22.1 CFM
+18.0 %
18.7 CFM
54.6 m³/h
+32.8 %
41.1 m³/h
40.7 m³/h
+26.4 %
32.2 m³/h
39.1 m³/h
+76.9 %
22.1 m³/h
37.5 m³/h
+17.9 %
31.8 m³/h
+12.3 %
0.91 mmH2O
+32.8 %
+32.8 %
+32.8 %
+12.5 %
0.09 hPa
+33.3 %
+33.3 %
+33.3 %
33.8
-26.6 %
24.8
31.6
-3.8 %
30.4
32.7
-0.9 %
32.4
32.1
-7.8 %
29.6
  • 703
  • 903
  • 1103
  • 1303
  • 1503
  • 1703
  • 1903
