Arctic
Corsair
P12 PWM PST RGB 0dB
QL120 RGB
159 g
163 g
500 U/min
1500 U/min
48.8 CFM
41.8 CFM
82.9 m³/h
1.85 mmH2O
1.55 mmH2O
26.0 dBA
Grau
Silber
Halbtransparent
Halbtransparent
4.0 V
3.0 V
2.9 V
380 U/min
245 U/min
532 U/min
472 U/min
1985 U/min
1600 U/min
32.1 CFM
+15.7 %
27.8 CFM
23.9 CFM
+16.3 %
20.6 CFM
23.0 CFM
+20.0 %
19.2 CFM
22.1 CFM
+28.0 %
17.2 CFM
54.6 m³/h
+15.7 %
47.2 m³/h
40.7 m³/h
+16.3 %
35.0 m³/h
39.1 m³/h
+19.9 %
32.6 m³/h
37.5 m³/h
+28.0 %
29.3 m³/h
+24.7 %
1.01 mmH2O
+22.0 %
+22.0 %
+52.5 %
0.40 mmH2O
+25.0 %
+20.0 %
+20.0 %
+50.0 %
33.8
-12.0 %
38.4
31.6
-17.5 %
38.3
32.7
-8.9 %
35.9
32.1
-10.3 %
35.8
