Arctic
Alpenföhn
P12 PWM PST RGB 0dB
Wing Boost 3
159 g
122 g
400 U/min
1050 U/min
48.8 CFM
60.6 CFM
82.9 m³/h
103.0 m³/h
1.85 mmH2O
22.0 dBA
Grau
Halbtransparent
4.0 V
4.7 V
2.9 V
2.0 V
380 U/min
443 U/min
532 U/min
174 U/min
1985 U/min
1075 U/min
477 U/min
32.1 CFM
+53.3 %
49.3 CFM
23.9 CFM
+2.0 %
23.5 CFM
23.0 CFM
+2.1 %
23.5 CFM
22.1 CFM
+6.8 %
20.7 CFM
54.6 m³/h
+53.3 %
83.7 m³/h
40.7 m³/h
+2.0 %
39.9 m³/h
39.1 m³/h
+2.1 %
39.9 m³/h
37.5 m³/h
+6.8 %
35.1 m³/h
+101.2 %
1.63 mmH2O
0.61
0.61
+22.0 %
+52.5 %
0.40 mmH2O
+100.0 %
0.16 hPa
0.06
0.06
+20.0 %
+50.0 %
33.8
-24.2 %
44.6
31.6
-33.2 %
47.3
32.7
-28.4 %
45.7
32.1
-25.9 %
43.3
