Arctic
P12 PWM PST RGB 0dB
Silent Wings 3
159 g
137 g
150 U/min
1450 U/min
48.8 CFM
50.5 CFM
82.9 m³/h
85.8 m³/h
1.85 mmH2O
1.79 mmH2O
16.4 dBA
Grau
Halbtransparent
4.0 V
4.1 V
2.9 V
3.9 V
380 U/min
532 U/min
206 U/min
244 U/min
1985 U/min
1411 U/min
32.1 CFM
+42.5 %
22.5 CFM
23.9 CFM
+20.4 %
19.9 CFM
23.0 CFM
+33.5 %
17.2 CFM
22.1 CFM
+31.6 %
16.8 CFM
54.6 m³/h
+42.5 %
38.3 m³/h
40.7 m³/h
+20.4 %
33.8 m³/h
39.1 m³/h
+33.4 %
29.3 m³/h
37.5 m³/h
+31.6 %
28.5 m³/h
+24.7 %
1.01 mmH2O
+16.4 %
+16.4 %
+22.0 %
+23.8 %
+16.0 %
+16.0 %
+22.4 %
33.8
-8.2 %
36.8
31.6
-24.4 %
41.8
32.7
-19.3 %
40.5
32.1
-20.9 %
40.6
