Arctic
Corsair
P12 PWM PST RGB 0dB
LL140 RGB
159 g
210 g
600 U/min
1300 U/min
48.8 CFM
51.5 CFM
82.9 m³/h
87.5 m³/h
1.85 mmH2O
1.52 mmH2O
25.0 dBA
Grau
Halbtransparent
Halbtransparent
4.0 V
2.9 V
2.9 V
380 U/min
226 U/min
532 U/min
378 U/min
1985 U/min
1319 U/min
32.1 CFM
+40.1 %
45.0 CFM
23.9 CFM
+18.5 %
28.4 CFM
23.0 CFM
+6.4 %
24.5 CFM
22.1 CFM
+19.7 %
26.4 CFM
54.6 m³/h
+40.1 %
76.5 m³/h
40.7 m³/h
+18.5 %
48.2 m³/h
39.1 m³/h
+6.4 %
41.6 m³/h
37.5 m³/h
+19.7 %
44.9 m³/h
+35.0 %
0.60 mmH2O
+22.0 %
+22.0 %
0.61
0.61
+33.3 %
+20.0 %
+20.0 %
0.06
0.06
33.8
-4.2 %
35.3
31.6
-14.4 %
36.9
32.7
-3.8 %
34
32.1
-7.8 %
34.8
