Arctic
Blacknoise
P12 PWM PST RGB 0dB
B14x-P-BL PWM ARGB
159 g
202 g
1500 U/min
0.5 W
2.9 W
48.8 CFM
110.0 CFM
82.9 m³/h
186.0 m³/h
1.85 mmH2O
2.30 mmH2O
29.6 dBA
Grau
Halbtransparent
4.0 V
4.3 V
2.9 V
380 U/min
335 U/min
532 U/min
154 U/min
1985 U/min
1487 U/min
32.1 CFM
+87.6 %
60.3 CFM
23.9 CFM
+38.8 %
33.2 CFM
23.0 CFM
+40.4 %
32.3 CFM
22.1 CFM
+50.7 %
33.2 CFM
54.6 m³/h
+87.6 %
102.4 m³/h
40.7 m³/h
+38.9 %
56.5 m³/h
39.1 m³/h
+40.4 %
54.9 m³/h
37.5 m³/h
+50.7 %
56.5 m³/h
+63.0 %
1.32 mmH2O
+116.4 %
1.32 mmH2O
+65.6 %
1.01 mmH2O
+100.0 %
1.22 mmH2O
+62.5 %
0.13 hPa
+116.7 %
0.13 hPa
+66.7 %
+100.0 %
0.12 hPa
33.8
-0.3 %
33.7
31.6
-15.5 %
37.4
32.7
-10.7 %
36.6
32.1
-10.8 %
36
