Arctic
Thermaltake
P12 PWM PST RGB 0dB
159 g
212 g
500 U/min
48.8 CFM
58.4 CFM
82.9 m³/h
99.1 m³/h
1.85 mmH2O
2.41 mmH2O
22.3 dBA
Grau
Grau
Halbtransparent
4.0 V
2.9 V
380 U/min
391 U/min
532 U/min
413 U/min
1985 U/min
1950 U/min
32.1 CFM
+3.3 %
33.2 CFM
23.9 CFM
+5.2 %
25.2 CFM
23.0 CFM
+6.4 %
24.5 CFM
22.1 CFM
+6.0 %
20.8 CFM
54.6 m³/h
+3.3 %
56.4 m³/h
40.7 m³/h
+5.2 %
42.8 m³/h
39.1 m³/h
+6.4 %
41.6 m³/h
37.5 m³/h
+6.0 %
35.4 m³/h
+127.2 %
1.84 mmH2O
+32.8 %
+22.0 %
+52.5 %
0.40 mmH2O
+125.5 %
0.18 hPa
+32.4 %
+22.4 %
+53.0 %
33.8
-9.6 %
37.4
31.6
-13.4 %
36.5
32.7
-9.2 %
36
32.1
-11.3 %
36.2
