Blacknoise
Arctic
B12x-PS-BL PWM ARGB
P12 PWM
120 g
139 g
200 U/min
1500 U/min
1800 U/min
58.1 CFM
56.3 CFM
98.7 m³/h
1.80 mmH2O
2.20 mmH2O
21.2 dBA
Silber
3.3 V
3.0 V
386 U/min
207 U/min
570 U/min
547 U/min
1491 U/min
1748 U/min
36.6 CFM
+9.1 %
33.5 CFM
23.5 CFM
+1.3 %
23.2 CFM
23.9 CFM
+4.1 %
23.0 CFM
22.8 CFM
+5.7 %
21.5 CFM
62.2 m³/h
+9.1 %
57.0 m³/h
40.0 m³/h
+1.3 %
39.5 m³/h
39.8 m³/h
+1.8 %
39.1 m³/h
38.7 m³/h
+5.7 %
36.6 m³/h
1.12 mmH2O
+124.0 %
+16.4 %
+22.0 %
+16.4 %
0.11 hPa
+120.0 %
+16.7 %
+20.0 %
+16.7 %
38.7
-5.2 %
36.7
37.9
-8.4 %
34.7
39.1
-11.3 %
34.7
37
-7.0 %
34.4
