Blacknoise
Cooler Master
B12x-PS-BL PWM ARGB
Masterfan MF120 Halo
120 g
180 g
650 U/min
1500 U/min
1800 U/min
58.1 CFM
47.2 CFM
98.7 m³/h
1.80 mmH2O
21.2 dBA
30.0 dBA
Grau
Halbtransparent
3.3 V
3.3 V
386 U/min
166 U/min
570 U/min
590 U/min
1491 U/min
1792 U/min
36.6 CFM
+47.8 %
24.8 CFM
23.5 CFM
+18.4 %
19.9 CFM
23.9 CFM
+18.3 %
20.2 CFM
22.8 CFM
+32.1 %
17.2 CFM
62.2 m³/h
+47.7 %
42.1 m³/h
40.0 m³/h
+18.3 %
33.8 m³/h
39.8 m³/h
+26.8 %
31.4 m³/h
38.7 m³/h
+32.1 %
29.3 m³/h
1.12 mmH2O
+180.0 %
0.40 mmH2O
+14.1 %
+52.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
0.11 hPa
+175.0 %
+14.3 %
+50.0 %
+75.0 %
38.7
-2.3 %
37.8
37.9
-4.0 %
36.4
39.1
-6.6 %
36.5
37
-3.8 %
35.6
