Blacknoise
Blacknoise
B12x-PS-BL PWM ARGB
NB-eLoop X PWM B12xP ARGB
120 g
120 g
400 U/min
1500 U/min
58.1 CFM
77.9 CFM
98.7 m³/h
132.4 m³/h
1.80 mmH2O
3.02 mmH2O
21.2 dBA
28.4 dBA
Grau
3.3 V
3.4 V
386 U/min
294 U/min
570 U/min
138 U/min
1491 U/min
2002 U/min
36.6 CFM
+10.8 %
40.5 CFM
23.5 CFM
+5.7 %
24.9 CFM
23.9 CFM
+4.1 %
23.0 CFM
22.8 CFM
+8.4 %
21.0 CFM
62.2 m³/h
+10.8 %
68.9 m³/h
40.0 m³/h
+5.7 %
42.3 m³/h
39.8 m³/h
+1.8 %
39.1 m³/h
38.7 m³/h
+8.4 %
35.7 m³/h
1.12 mmH2O
+27.7 %
1.43 mmH2O
+14.1 %
0.61
0.61
+42.0 %
0.11 hPa
+27.3 %
0.14 hPa
+14.3 %
0.06
0.06
+40.0 %
38.7
-11.1 %
34.4
37.9
-3.7 %
36.5
39.1
-8.2 %
35.9
37
-2.4 %
36.1
