Blacknoise
Alphacool
B12x-PS-BL PWM ARGB
Rise Aurora
120 g
180 g
1500 U/min
2500 U/min
58.1 CFM
70.0 CFM
98.7 m³/h
118.9 m³/h
1.80 mmH2O
3.17 mmH2O
21.2 dBA
31.5 dBA
3.3 V
3.0 V
2.9 V
386 U/min
862 U/min
570 U/min
874 U/min
339 U/min
181 U/min
1491 U/min
2775 U/min
1045 U/min
36.6 CFM
+26.2 %
29.0 CFM
23.5 CFM
+3.7 %
24.4 CFM
23.9 CFM
+2.0 %
23.5 CFM
22.8 CFM
+3.2 %
22.1 CFM
62.2 m³/h
+26.2 %
49.3 m³/h
40.0 m³/h
+3.8 %
41.5 m³/h
39.8 m³/h
+0.3 %
39.9 m³/h
38.7 m³/h
+3.2 %
37.5 m³/h
1.12 mmH2O
+83.1 %
+39.3 %
0.51 mmH2O
+49.5 %
0.41 mmH2O
+74.1 %
0.41 mmH2O
0.11 hPa
+83.3 %
+40.0 %
+50.0 %
+75.0 %
38.7
-7.0 %
41.6
37.9
-7.6 %
41
39.1
39.1
37
-8.6 %
40.5
