Blacknoise
Arctic
B12x-PS-BL PWM ARGB
P14 PWM
120 g
194 g
200 U/min
1500 U/min
1700 U/min
58.1 CFM
72.8 CFM
98.7 m³/h
123.8 m³/h
1.80 mmH2O
2.40 mmH2O
21.2 dBA
3.3 V
3.8 V
386 U/min
395 U/min
570 U/min
481 U/min
1491 U/min
1733 U/min
36.6 CFM
+24.8 %
45.7 CFM
23.5 CFM
+15.0 %
27.1 CFM
23.9 CFM
+7.6 %
25.8 CFM
22.8 CFM
+18.6 %
27.0 CFM
62.2 m³/h
+24.8 %
77.6 m³/h
40.0 m³/h
+15.0 %
46.0 m³/h
39.8 m³/h
+10.1 %
43.8 m³/h
38.7 m³/h
+18.6 %
45.9 m³/h
1.12 mmH2O
+86.7 %
0.60 mmH2O
+77.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
0.11 hPa
+83.3 %
+75.0 %
+50.0 %
+75.0 %
38.7
-20.7 %
30.7
37.9
-19.8 %
30.4
39.1
-23.3 %
30
37
-17.3 %
30.6
