Arctic
P12 PWM
Pure Wings 2
139 g
93 g
200 U/min
300 U/min
1800 U/min
1500 U/min
56.3 CFM
51.4 CFM
2.20 mmH2O
1.25 mmH2O
20.2 dBA
Silber
3.0 V
207 U/min
202 U/min
547 U/min
324 U/min
1748 U/min
1488 U/min
33.5 CFM
+6.5 %
31.5 CFM
23.2 CFM
+5.3 %
22.1 CFM
23.0 CFM
+8.0 %
21.3 CFM
21.5 CFM
+3.4 %
20.8 CFM
57.0 m³/h
+6.5 %
53.5 m³/h
39.5 m³/h
+5.3 %
37.5 m³/h
39.1 m³/h
+8.0 %
36.2 m³/h
36.6 m³/h
+3.4 %
35.4 m³/h
+42.0 %
+16.4 %
0.5
0.5
+22.0 %
+40.0 %
+16.7 %
0.05
0.05
+20.0 %
36.7
-3.9 %
38.2
34.7
-5.4 %
36.7
34.7
-3.6 %
36
34.4
-5.0 %
36.2
