Arctic
Alphacool
P12 PWM
Rise Aurora
139 g
200 U/min
1800 U/min
6.6 W
56.3 CFM
90.7 CFM
154.1 m³/h
2.20 mmH2O
2.20 mmH2O
38.4 dBA
Silber
3.0 V
2.9 V
207 U/min
883 U/min
547 U/min
553 U/min
331 U/min
145 U/min
1748 U/min
2108 U/min
677 U/min
33.5 CFM
+50.2 %
50.4 CFM
23.2 CFM
+14.7 %
26.7 CFM
23.0 CFM
+5.4 %
21.8 CFM
21.5 CFM
+4.9 %
20.5 CFM
57.0 m³/h
+50.2 %
85.6 m³/h
39.5 m³/h
+14.7 %
45.3 m³/h
39.1 m³/h
+5.4 %
37.1 m³/h
36.6 m³/h
+4.9 %
34.9 m³/h
+102.0 %
1.01 mmH2O
+1.7 %
0.60 mmH2O
+42.0 %
+32.8 %
+100.0 %
0.06
0.06
+40.0 %
+33.3 %
36.7
-6.9 %
39.4
34.7
-11.5 %
39.2
34.7
-11.0 %
39
34.4
-8.8 %
37.7
  • 331
  • 531
  • 731
  • 931
  • 1131
  • 1331
  • 1531
  • 1731
  • 1931
