Arctic
MSI
P12 PWM
MEG Silent Gale P12
27.5 mm
139 g
209 g
200 U/min
1800 U/min
0.7 W
1.4 W
56.3 CFM
56.2 CFM
95.5 m³/h
2.20 mmH2O
2.21 mmH2O
22.7 dBA
Silber
5.5 V
3.0 V
4.3 V
207 U/min
906 U/min
547 U/min
742 U/min
194 U/min
186 U/min
1748 U/min
1980 U/min
512 U/min
33.5 CFM
+7.7 %
31.1 CFM
23.2 CFM
+7.9 %
21.5 CFM
23.0 CFM
+4.3 %
22.1 CFM
21.5 CFM
+9.5 %
19.7 CFM
57.0 m³/h
+7.8 %
52.9 m³/h
39.5 m³/h
+7.9 %
36.6 m³/h
39.1 m³/h
+4.3 %
37.5 m³/h
36.6 m³/h
+9.6 %
33.4 m³/h
+82.0 %
0.91 mmH2O
+32.8 %
+62.0 %
+32.8 %
+80.0 %
0.09 hPa
+33.3 %
+60.0 %
+33.3 %
36.7
-15.0 %
31.2
34.7
-0.3 %
34.8
34.7
-0.3 %
34.6
34.4
-3.8 %
33.1
