Arctic
Lian Li
P12 PWM
UNI FAN SL120 ARGB
139 g
232 g
200 U/min
800 U/min
1800 U/min
1900 U/min
56.3 CFM
58.5 CFM
99.5 m³/h
2.20 mmH2O
1.67 mmH2O
31.0 dBA
Silber
Silber
3.0 V
2.4 V
207 U/min
412 U/min
547 U/min
98 U/min
1748 U/min
1828 U/min
33.5 CFM
+44.3 %
23.2 CFM
23.2 CFM
+31.2 %
17.7 CFM
23.0 CFM
+45.4 %
15.8 CFM
21.5 CFM
+40.8 %
15.3 CFM
57.0 m³/h
+44.3 %
39.5 m³/h
39.5 m³/h
+31.2 %
30.1 m³/h
39.1 m³/h
+45.4 %
26.9 m³/h
36.6 m³/h
+40.8 %
26.0 m³/h
+25.0 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+25.0 %
+50.0 %
+25.0 %
+50.0 %
36.7
-5.4 %
38.8
34.7
-5.4 %
36.7
34.7
-3.9 %
36.1
34.4
-0.6 %
34.6
