Arctic
Noctua
P12 PWM
NF-A14 FLX
139 g
210 g
200 U/min
900 U/min
1800 U/min
1200 U/min
56.3 CFM
68.0 CFM
115.5 m³/h
2.20 mmH2O
1.51 mmH2O
19.2 dBA
Beige
Silber
Braun
Braun
4.6 V
3.0 V
4.2 V
207 U/min
381 U/min
547 U/min
469 U/min
1748 U/min
1199 U/min
33.5 CFM
+59.5 %
53.5 CFM
23.2 CFM
+41.8 %
33.0 CFM
23.0 CFM
+37.6 %
31.7 CFM
21.5 CFM
+39.9 %
30.1 CFM
57.0 m³/h
+59.5 %
90.9 m³/h
39.5 m³/h
+41.8 %
56.0 m³/h
39.1 m³/h
+37.6 %
53.8 m³/h
36.6 m³/h
+39.9 %
51.2 m³/h
+82.0 %
0.91 mmH2O
+49.2 %
0.91 mmH2O
0.5
0.5
+103.3 %
0.30 mmH2O
+80.0 %
0.09 hPa
+50.0 %
0.09 hPa
0.05
0.05
+100.0 %
0.03 hPa
36.7
-6.8 %
34.2
34.7
-18.5 %
42.6
34.7
-15.0 %
40.8
34.4
-13.8 %
39.9
