Arctic
Thermaltake
P12 PWM
139 g
212 g
200 U/min
500 U/min
1800 U/min
56.3 CFM
58.4 CFM
99.1 m³/h
2.20 mmH2O
2.41 mmH2O
22.3 dBA
Silber
Grau
3.0 V
207 U/min
391 U/min
547 U/min
413 U/min
1748 U/min
1950 U/min
33.5 CFM
+1.1 %
33.2 CFM
23.2 CFM
+8.4 %
25.2 CFM
23.0 CFM
+6.4 %
24.5 CFM
21.5 CFM
+3.4 %
20.8 CFM
57.0 m³/h
+1.1 %
56.4 m³/h
39.5 m³/h
+8.3 %
42.8 m³/h
39.1 m³/h
+6.4 %
41.6 m³/h
36.6 m³/h
+3.4 %
35.4 m³/h
+268.0 %
1.84 mmH2O
+32.8 %
0.5
0.5
+52.5 %
0.40 mmH2O
+260.9 %
0.18 hPa
+32.4 %
+2.0 %
+53.0 %
36.7
-1.9 %
37.4
34.7
-4.9 %
36.5
34.7
-3.6 %
36
34.4
-5.0 %
36.2
