Cooler Master
Arctic
Masterfan MF120 Halo
P12 PWM PST RGB 0dB
180 g
159 g
650 U/min
1800 U/min
47.2 CFM
48.8 CFM
82.9 m³/h
1.85 mmH2O
30.0 dBA
Grau
Grau
Halbtransparent
Halbtransparent
3.3 V
4.0 V
2.9 V
166 U/min
380 U/min
590 U/min
532 U/min
1792 U/min
1985 U/min
24.8 CFM
+29.7 %
32.1 CFM
19.9 CFM
+20.4 %
23.9 CFM
20.2 CFM
+13.7 %
23.0 CFM
17.2 CFM
+28.0 %
22.1 CFM
42.1 m³/h
+29.7 %
54.6 m³/h
33.8 m³/h
+20.4 %
40.7 m³/h
31.4 m³/h
+24.5 %
39.1 m³/h
29.3 m³/h
+28.0 %
37.5 m³/h
0.40 mmH2O
+102.5 %
+32.8 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
+100.0 %
+33.3 %
+50.0 %
+50.0 %
37.8
-10.6 %
33.8
36.4
-13.2 %
31.6
36.5
-10.4 %
32.7
35.6
-9.8 %
32.1
