Cooler Master
Lian Li
Masterfan MF120 Halo
Uni Fan AL V2 120
28 mm
180 g
240 g
650 U/min
250 U/min
1800 U/min
0.7 W
2.1 W
47.2 CFM
77.3 CFM
131.3 m³/h
2.97 mmH2O
30.0 dBA
28.7 dBA
Einzelreview
Grau
Halbtransparent
3.3 V
3.0 V
166 U/min
762 U/min
590 U/min
749 U/min
297 U/min
198 U/min
1792 U/min
820 U/min
24.8 CFM
+94.6 %
48.2 CFM
19.9 CFM
+102.1 %
40.2 CFM
20.2 CFM
+48.7 %
30.1 CFM
17.2 CFM
+139.0 %
41.2 CFM
42.1 m³/h
+94.5 %
81.9 m³/h
33.8 m³/h
+102.1 %
68.3 m³/h
31.4 m³/h
+62.9 %
51.1 m³/h
29.3 m³/h
+138.9 %
70.0 m³/h
0.40 mmH2O
+333.4 %
1.73 mmH2O
+88.9 %
1.53 mmH2O
0.40 mmH2O
+155.0 %
1.02 mmH2O
0.40 mmH2O
+307.5 %
1.63 mmH2O
+325.0 %
0.17 hPa
+87.5 %
0.15 hPa
+150.0 %
+300.0 %
0.16 hPa
37.8
-16.7 %
31.5
36.4
-20.1 %
29.1
36.5
-16.4 %
30.5
35.6
-15.4 %
30.1
  • 297
  • 497
  • 697
  • 897
  • 1097
  • 1297
  • 1497
  • 1697
  • 1897
