Cooler Master
NZXT
Masterfan MF120 Halo
F120 RGB
26 mm
180 g
205 g
650 U/min
500 U/min
1800 U/min
1800 U/min
0.4 W
1.8 W
47.2 CFM
50.2 CFM
85.2 m³/h
2.70 mmH2O
30.0 dBA
27.5 dBA
Grau
Halbtransparent
3.3 V
4.7 V
4.4 V
166 U/min
827 U/min
590 U/min
703 U/min
1792 U/min
1924 U/min
447 U/min
24.8 CFM
+2.4 %
24.2 CFM
19.9 CFM
+5.0 %
18.9 CFM
20.2 CFM
+55.7 %
13.0 CFM
17.2 CFM
+8.5 %
18.7 CFM
42.1 m³/h
+2.4 %
41.1 m³/h
33.8 m³/h
+5.0 %
32.2 m³/h
31.4 m³/h
+42.1 %
22.1 m³/h
29.3 m³/h
+8.5 %
31.8 m³/h
0.40 mmH2O
+127.5 %
0.91 mmH2O
0.81
0.81
0.40 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
+125.0 %
0.09 hPa
0.08
0.08
+100.0 %
+100.0 %
37.8
-34.4 %
24.8
36.4
-16.5 %
30.4
36.5
-11.2 %
32.4
35.6
-16.9 %
29.6
  • 703
  • 903
  • 1103
  • 1303
  • 1503
  • 1703
  • 1903
