Cooler Master
Corsair
Masterfan MF120 Halo
ML 120 RGB Elite
180 g
186 g
650 U/min
450 U/min
1800 U/min
1.6 W
47.2 CFM
58.1 CFM
98.7 m³/h
2.90 mmH2O
30.0 dBA
30.4 dBA
Grau
Halbtransparent
3.3 V
3.0 V
166 U/min
510 U/min
590 U/min
450 U/min
169 U/min
84 U/min
1792 U/min
1993 U/min
24.8 CFM
+42.3 %
35.2 CFM
19.9 CFM
+21.6 %
24.2 CFM
20.2 CFM
+17.1 %
23.7 CFM
17.2 CFM
+23.5 %
21.3 CFM
42.1 m³/h
+42.3 %
59.9 m³/h
33.8 m³/h
+21.6 %
41.1 m³/h
31.4 m³/h
+28.3 %
40.3 m³/h
29.3 m³/h
+23.5 %
36.2 m³/h
0.40 mmH2O
+77.5 %
+32.8 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+77.5 %
+75.0 %
+33.3 %
+50.0 %
+75.0 %
37.8
-24.6 %
28.5
36.4
-19.0 %
29.5
36.5
-21.9 %
28.5
35.6
-21.9 %
27.8
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
