Cooler Master
Masterfan MF120 Halo
Light Wings PWM HS
180 g
210 g
650 U/min
300 U/min
1800 U/min
2500 U/min
1.4 W
5.4 W
47.2 CFM
52.3 CFM
88.9 m³/h
2.60 mmH2O
30.0 dBA
31.0 dBA
Grau
Halbtransparent
3.3 V
166 U/min
608 U/min
590 U/min
565 U/min
1792 U/min
2489 U/min
248 U/min
24.8 CFM
+31.4 %
32.5 CFM
19.9 CFM
+7.6 %
18.5 CFM
20.2 CFM
+6.8 %
18.9 CFM
17.2 CFM
+2.7 %
17.7 CFM
42.1 m³/h
+31.4 %
55.3 m³/h
33.8 m³/h
+7.6 %
31.4 m³/h
31.4 m³/h
+2.5 %
32.2 m³/h
29.3 m³/h
+2.7 %
30.1 m³/h
0.40 mmH2O
+77.5 %
+62.0 %
0.4
0.4
0.40 mmH2O
+25.0 %
+75.0 %
+60.0 %
0.04
0.04
+25.0 %
37.8
-10.8 %
33.7
36.4
-13.2 %
31.6
36.5
-12.3 %
32
35.6
-13.8 %
30.7
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
