Cooler Master
Alphacool
Masterfan MF120 Halo
Rise Aurora
180 g
650 U/min
1800 U/min
6.6 W
47.2 CFM
90.7 CFM
154.1 m³/h
2.20 mmH2O
30.0 dBA
38.4 dBA
Grau
Halbtransparent
3.3 V
2.9 V
166 U/min
883 U/min
590 U/min
553 U/min
331 U/min
145 U/min
1792 U/min
2108 U/min
677 U/min
24.8 CFM
+103.4 %
50.4 CFM
19.9 CFM
+34.0 %
26.7 CFM
20.2 CFM
+7.9 %
21.8 CFM
17.2 CFM
+19.1 %
20.5 CFM
42.1 m³/h
+103.3 %
85.6 m³/h
33.8 m³/h
+34.0 %
45.3 m³/h
31.4 m³/h
+18.2 %
37.1 m³/h
29.3 m³/h
+19.1 %
34.9 m³/h
0.40 mmH2O
+152.5 %
1.01 mmH2O
+35.0 %
0.60 mmH2O
0.40 mmH2O
+77.5 %
0.40 mmH2O
+102.5 %
+150.0 %
+33.3 %
+75.0 %
+100.0 %
37.8
-4.1 %
39.4
36.4
-7.1 %
39.2
36.5
-6.4 %
39
35.6
-5.6 %
37.7
  • 331
  • 531
  • 731
  • 931
  • 1131
  • 1331
  • 1531
  • 1731
  • 1931
