Cooler Master
Alpenföhn
Masterfan MF120 Halo
Wing Boost 3
180 g
122 g
650 U/min
400 U/min
1800 U/min
1050 U/min
47.2 CFM
60.6 CFM
103.0 m³/h
30.0 dBA
22.0 dBA
Grau
Halbtransparent
3.3 V
4.7 V
2.0 V
166 U/min
443 U/min
590 U/min
174 U/min
1792 U/min
1075 U/min
477 U/min
24.8 CFM
+98.9 %
49.3 CFM
19.9 CFM
+18.1 %
23.5 CFM
20.2 CFM
+16.0 %
23.5 CFM
17.2 CFM
+19.8 %
20.7 CFM
42.1 m³/h
+98.8 %
83.7 m³/h
33.8 m³/h
+18.0 %
39.9 m³/h
31.4 m³/h
+27.1 %
39.9 m³/h
29.3 m³/h
+19.8 %
35.1 m³/h
0.40 mmH2O
+307.5 %
1.63 mmH2O
+32.8 %
0.40 mmH2O
+25.0 %
0.4
0.4
+300.0 %
0.16 hPa
+33.3 %
+25.0 %
0.04
0.04
37.8
-15.2 %
44.6
36.4
-23.0 %
47.3
36.5
-20.1 %
45.7
35.6
-17.8 %
43.3
